2020-06-20T02:59:17.018+0200 FATAL Unrecoverable error {“error”: “debug: http: Server closed”, “errorVerbose”: “debug: http: Server closed\n\tstorj.io/private/debug.(*Server).Run.func2:108\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
today I have so much troubles with the movistar connection but now they solved , but when I check the server ,it still offline , it was online since 15 may
( I know my English is not as good as it should)
Make sure the WAN IP you see in your router settings matches the IP shown on the above page.
Make sure your port forward is set up correctly. That means no filter on incoming IPs, forwarding to the IP of your node on the local lan. Set to TCP and port 28967.
If you’re running a firewall, make sure you allow incoming traffic on port 28967.
Make sure you’re not blocking any outgoing traffic from your node’s IP to any port. Make an explicit rule to allow that if needed.
but I dont know how to check the identity bcs I dont have docker
I check the log today and I saw this extra lines :
2020-06-20T03:00:34.218+0200 INFO Public server started on [::]:28967
2020-06-20T03:00:34.218+0200 INFO Private server started on 127.0.0.1:7778
2020-06-20T03:00:34.219+0200 INFO trust Scheduling next refresh {“after”: “8h40m39.13464091s”}
2020-06-20T03:00:34.218+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T03:31:17.922+0200 INFO Interrogate request received.
2020-06-20T04:00:34.233+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T05:00:34.227+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T06:00:34.229+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T07:00:34.220+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T08:00:34.226+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T09:00:34.232+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T10:00:34.219+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T11:00:34.223+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T11:41:13.863+0200 INFO trust Scheduling next refresh {“after”: “5h44m53.74508084s”}
2020-06-20T12:00:34.220+0200 INFO bandwidth Performing bandwidth usage rollups
2020-06-20T13:00:34.223+0200 INFO bandwidth Performing bandwidth usage rollups
the noip duc its running correctly but I think that I used in the gui the ip like 185.105.38.27:28967 insted of my.ddns.net:28968 or something similar , how can I check that? or how can I change it ?
