Hi All,
From yesterday i didn’t see any updates on my dashboard when clicked refresh button. I restarted the node and now it don’t want start again. Please see below log:
2023-04-18T18:04:27.491+0100 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2023-04-18T18:04:27.494+0100 INFO Anonymized tracing enabled
2023-04-18T18:04:27.499+0100 INFO Operator email {“Address”: “"}
2023-04-18T18:04:27.499+0100 INFO Operator wallet {“Address”: "”}
2023-04-18T18:04:27.520+0100 FATAL Unrecoverable error {“error”: “Error starting master database on storagenode: database: bandwidth opening file "D:\\bandwidth.db" failed: file is not a database\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:331\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:308\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:283\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:250\n\tmain.cmdRun:193\n\tstorj.io/private/process.cleanup.func1.4:377\n\tstorj.io/private/process.cleanup.func1:395\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:92\n\tstorj.io/private/process.ExecWithCustomConfig:74\n\tstorj.io/private/process.Exec:64\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”, “errorVerbose”: “Error starting master database on storagenode: database: bandwidth opening file "D:\\bandwidth.db" failed: file is not a database\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:331\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:308\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:283\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:250\n\tmain.cmdRun:193\n\tstorj.io/private/process.cleanup.func1.4:377\n\tstorj.io/private/process.cleanup.func1:395\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:92\n\tstorj.io/private/process.ExecWithCustomConfig:74\n\tstorj.io/private/process.Exec:64\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75\n\tmain.cmdRun:195\n\tstorj.io/private/process.cleanup.func1.4:377\n\tstorj.io/private/process.cleanup.func1:395\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:92\n\tstorj.io/private/process.ExecWithCustomConfig:74\n\tstorj.io/private/process.Exec:64\n\tmain.(*service).Execute.func1:61\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
Could you please help me to resolve this issue?
Regards
