Fell there are a problem with my note are there other worng ind "bandwidthdb: database is locked"
Hi my note have stop growing and start just go back so will really be happy if one like too just view my look or there see some other error ind I just to late to get new data and not some serious error error
whem wrote this I fond bandwidthdb: database is locked should I try move the database out to a ssd ?
2023-08-25T15:32:03+02:00	INFO	Configuration loaded	{"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-08-25T15:32:03+02:00	INFO	Anonymized tracing enabled	{"process": "storagenode"}
2023-08-25T15:32:03+02:00	INFO	Operator email	{"process": "storagenode", "Address": "xxxx"}
2023-08-25T15:32:03+02:00	INFO	Operator wallet	{"process": "storagenode", "Address": "xxxx"}
2023-08-25T15:32:03+02:00	INFO	server	kernel support for server-side tcp fast open remains disabled.	{"process": "storagenode"}
2023-08-25T15:32:03+02:00	INFO	server	enable with: sysctl -w net.ipv4.tcp_fastopen=3	{"process": "storagenode"}
2023-08-25T15:32:05+02:00	INFO	Telemetry enabled	{"process": "storagenode", "instance ID": "1u5CKqKdfwvLH19SkKr9vE2thoWGiBUDaPRFJsRmdYTHEAZ4vs"}
2023-08-25T15:32:05+02:00	INFO	Event collection enabled	{"process": "storagenode", "instance ID": "1u5CKqKdfwvLH19SkKr9vE2thoWGiBUDaPRFJsRmdYTHEAZ4vs"}
2023-08-25T15:32:05+02:00	INFO	db.migration	Database Version	{"process": "storagenode", "version": 54}
2023-08-25T15:32:10+02:00	INFO	preflight:localtime	start checking local system clock with trusted satellites' system clock.	{"process": "storagenode"}
2023-08-25T15:32:10+02:00	INFO	preflight:localtime	local system clock is in sync with trusted satellites' system clock.	{"process": "storagenode"}
2023-08-25T15:32:10+02:00	INFO	Node 1u5CKqKdfwvLH19SkKr9vE2thoWGiBUDaPRFJsRmdYTHEAZ4vs started	{"process": "storagenode"}
2023-08-25T15:32:10+02:00	INFO	trust	Scheduling next refresh	{"process": "storagenode", "after": "5h59m49.06551559s"}
2023-08-25T15:32:10+02:00	INFO	bandwidth	Performing bandwidth usage rollups	{"process": "storagenode"}
2023-08-25T15:32:10+02:00	INFO	Public server started on [::]:28967	{"process": "storagenode"}
2023-08-25T15:32:10+02:00	INFO	Private server started on 127.0.0.1:7778	{"process": "storagenode"}
|2023-08-25T15:32:10+02:00|INFO|pieces:trash|emptying trash started|{process: storagenode, Satellite ID: 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB}|
|2023-08-25T15:32:11+02:00|INFO|lazyfilewalker.used-space-filewalker|starting subprocess|{process: storagenode, satelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}|
|2023-08-25T15:32:11+02:00|INFO|lazyfilewalker.used-space-filewalker|subprocess started|{process: storagenode, satelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs}|
|2023-08-25T15:32:11+02:00|INFO|lazyfilewalker.used-space-filewalker.subprocess|Database started|{process: storagenode, satelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, process: storagenode}|
|2023-08-25T15:32:11+02:00|INFO|lazyfilewalker.used-space-filewalker.subprocess|used-space-filewalker started|{process: storagenode, satelliteID: 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs, process: storagenode}|
|2023-08-25T15:32:11+02:00|INFO|piecestore|upload started|{process: storagenode, Piece ID: POHTWXCVZFB4DGYBENAZTSGIMCPI5ZVRKH6MTV4LGRVJJEFFAU3Q, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Available Space: 8848632265082, Remote Address: 5.161.128.79:38108}|
|2023-08-25T15:32:11+02:00|INFO|piecestore|upload started|{process: storagenode, Piece ID: IL6XVYSGKB4M3RPAVG2C6QDPNCEISJZT4NCUJ5T5IIGMXOPQ43AQ, Satellite ID: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S, Action: PUT, Available Space: 8848632265082, Remote Address: 5.161.128.79:38494}|
2023-08-26T00:38:59+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7.1:737\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7:775\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:792\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:38:59+02:00	INFO	piecestore	downloaded	{"process": "storagenode", "Piece ID": "HFGBDAMCHZAMB2D6VEAJN6IOOVYEYEA6NVL4A47ED4VCLGCKDG2Q", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 9472, "Remote Address": "5.161.123.49:53822"}
2023-08-26T00:38:59+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:532\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:38:59+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "FPICLAHHQOXOHHEJIVJHTLNDBG3AUQ6QZ7WG4ZBB22PN3ZULLXIA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT_REPAIR", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:531\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 65792, "Remote Address": "5.161.211.30:46922"}
2023-08-26T00:38:59+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:507\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:38:59+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "HPKNXSNPMDIVEAOW2WTPM4T2LTGRPJUWNVAUTBH5XANMSAISZGGQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 17408, "Remote Address": "5.161.143.41:56660"}
2023-08-26T00:38:59+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "3NP7BFNGZJDZ5QZL7CLVJPFAMAPPWCHO6F2557BOJJBICZS6AKOA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 36864, "Remote Address": "5.161.128.79:21388"}
2023-08-26T00:38:59+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "OBHRDTQWGQZOPPKDFRFDRZGJA2ZU4E4IZUA6GYAIKFMWCIV3HIXQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846090334586, "Remote Address": "5.161.128.79:21388"}
2023-08-26T00:39:09+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:507\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:09+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "FPZ7WDLD3BPFPORKLPM2V6C3KAK3XDHN2KXDTRDRDHCIMF765Y3A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 36864, "Remote Address": "5.161.128.79:9784"}
2023-08-26T00:39:09+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "7YQ5N5WL4TGM25MHELJDMSP6QRS2CNRZGJX5VCEDQUKYL6AJTP7A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 36864, "Remote Address": "5.161.128.79:15474"}
2023-08-26T00:39:09+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "TRPGQWDEELGRTS4MCH5NBWOGHKVHVWIPJVUFH2AUGEL4ZE5AGASQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089716602, "Remote Address": "5.161.128.79:9784"}
2023-08-26T00:39:09+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "EEBKECHKR4MTCIVFEV7A73AY3VPZOLIICELVRPOONW342WKFOUVA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089716602, "Remote Address": "5.161.128.79:15474"}
2023-08-26T00:39:09+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "NTSGMACUNFD6TZU2PJ44I5US6RD3P5ZEZG3YTIWMH6DT6FEBBVNA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 36864, "Remote Address": "5.161.128.79:21372"}
2023-08-26T00:39:09+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "TJNVG6NAZT2BQOIOR6VCLVWIWCDYDBGC75KHMAK63KHDM6JQJY2A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089642106, "Remote Address": "5.161.128.79:21372"}
2023-08-26T00:39:09+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "QWGRWANFH5MQGINRFI7UQMEINYT2BG7ZSLE74WKYD5YCGI2W5NCA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 18688, "Remote Address": "5.161.149.40:42994"}
2023-08-26T00:39:09+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "DLYENP47NPXPG66RQUOT4ZGYUUHCU26P6WN4DM7GFB43YEGZDLKA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089605242, "Remote Address": "5.161.149.40:42994"}
2023-08-26T00:39:12+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "ZTQT5J6WVKRJP6K3W3EDGYVFXVIEVD77TEIS5EV7JAI3RJKJCCDQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT_REPAIR", "Available Space": 8846089586042, "Remote Address": "5.161.50.62:56242"}
2023-08-26T00:39:13+02:00	INFO	piecestore	download started	{"process": "storagenode", "Piece ID": "6QY4L6WLZL2XDW757UWED675IETONFHAY4E55W5HLBAQA7UWFPQA", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET", "Offset": 0, "Size": 5632, "Remote Address": "5.161.197.155:54138"}
2023-08-26T00:39:19+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7.1:737\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7:778\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:792\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:19+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:532\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:19+02:00	INFO	piecestore	uploaded	{"process": "storagenode", "Piece ID": "RIA3I5QZBMCOEJVUZZ5E4NKEV5KGTVGAXJ23MWXZOMNXCI32L3IQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT_REPAIR", "Size": 580096, "Remote Address": "59.127.219.133:50531"}
2023-08-26T00:39:19+02:00	INFO	piecestore	download canceled	{"process": "storagenode", "Piece ID": "DODCU3UTDQBR635OXK5HB7NJUMZWAOZ73CDTKRZ5ISV6ZJGLARLA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET", "Offset": 2170624, "Size": 0, "Remote Address": "184.104.224.99:52262"}
2023-08-26T00:39:19+02:00	INFO	piecestore	download started	{"process": "storagenode", "Piece ID": "54TAYSCNFQ6F7QJAPFHFFWZ6ZQGUKSVVMQLJCI3LALBXBNXRTZZA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET", "Offset": 1726976, "Size": 2304, "Remote Address": "184.104.224.99:52262"}
2023-08-26T00:39:19+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:507\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:19+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "DSLW6IO5OYME7LZUUGOZSH7JY74NW4AUQALKICH6WP3MVFN3R2UQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 13056, "Remote Address": "5.161.143.41:27976"}
2023-08-26T00:39:19+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "5CWTRP33XAHL5L2RZBMNWP4WVM6MB4MCM6LJTVRH4N6TD7CHJL3A", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089548666, "Remote Address": "5.161.143.41:27976"}
2023-08-26T00:39:19+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7.1:737\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func7:775\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:792\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:19+02:00	INFO	piecestore	downloaded	{"process": "storagenode", "Piece ID": "E6U47UAAOEUJ4SJDG767RLMBYNDLIFWALQHYV3PPCF6VF33EDMPQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR", "Offset": 0, "Size": 14592, "Remote Address": "5.161.217.169:57444"}
2023-08-26T00:39:29+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:507\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2023-08-26T00:39:29+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "4EM3UY26NCYWARTIGHOBLXSRVP5PITSTLJZHBGPJ5R62B3MB7J2A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 768, "Remote Address": "50.7.22.66:22918"}
2023-08-26T00:39:29+02:00	ERROR	piecestore	upload failed	{"process": "storagenode", "Piece ID": "VVSHKFWADFGLEGVB4CK72DYJSFO3ZYQ5QPIUPIJ4B5KVNHBM7RWQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "error": "context canceled", "errorVerbose": "context canceled\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload.func6:500\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:506\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35", "Size": 32000, "Remote Address": "216.66.40.82:58984"}
2023-08-26T00:39:29+02:00	INFO	piecestore	upload started	{"process": "storagenode", "Piece ID": "T2VPDEKLXZ36EE5EML4PR6MVTAJWB3YYDVDSSBZSKO2TDKGUVGFQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "PUT", "Available Space": 8846089533050, "Remote Address": "216.66.40.82:58984"}
2023-08-26T00:39:29+02:00	ERROR	piecestore	failed to add bandwidth usage	{"process": "storagenode", "error": "bandwidthdb: database is locked", "errorVerbose": "bandwidthdb: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*bandwidthDB).Add:60\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).beginSaveOrder.func1:868\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Upload:532\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func1:243\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
Yes you should move your dbs to SSD.
Thx just move it now
If you can, please describe your setup, software, hardware, disk type (SMR/CMR), etc. just to have a refference of why your node is performing pourly. For a good setup, like a PC or NAS, with 7200rpm CMR drives, usualy there is no need for SSD.
setup
OS Unriad storj on docker
CPU Ryzen 7 5700G
RAM 8 GiB DDR4
Disks
Parity TOSHIBA_MG09ACA18TE 18TB CMR
DISK 1 WDC_WD120EMFZ 12TB CMR
DISK 2 WDC_WD80EMAZ 8TB CMR
catch WD Red SA500 SSD
Testers report that Toshiba is slower than others. Vadim uses them and he also was forced to use SSDs.
