Please make sure that we do not have any duplicates already open.
You ca…n ensure this by searching the issue list for this repository.
If there is a duplicate, please close your issue and add a comment to the
existing issue instead.
For more information about reporting issues, see
https://github.com/storj/storj/blob/main/docs/storagenode/CONTRIBUTING.md
GENERAL SUPPORT INFORMATION
The GitHub issue tracker is for bug reports and feature requests.
General support can be found at the following locations:
- Storj Community Forum - https://forum.storj.io
- File a ticket at https://support.storj.io/
BUG REPORT INFORMATION
**Description**
Looks like the satellite keeps auditing the same file, despite it does not exist on the node.
Does this strike the audit score each time a GET_AUDIT fails or just once for that particular piece ID?
**Logs**
root@server030:/disk102/storj/logs/storagenode# grep "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROM" server033-v1.76.2-30033.log ./old/server033* | sort
./old/server033-v1.74.1-30033.log:2023-03-14T01:03:28.160+0100 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "35.189.253.221:35210"}
./old/server033-v1.74.1-30033.log:2023-03-14T01:03:28.239+0100 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "35.189.253.221:35210", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.74.1-30033.log:2023-03-17T07:44:09.118+0100 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "35.205.252.199:58966"}
./old/server033-v1.74.1-30033.log:2023-03-17T07:44:09.140+0100 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "35.205.252.199:58966", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.74.1-30033.log:2023-03-20T02:10:21.216+0100 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "35.205.252.199:51888"}
./old/server033-v1.74.1-30033.log:2023-03-20T02:10:21.250+0100 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "35.205.252.199:51888", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-03-23T02:06:58.381+0100 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "35.205.252.199:52090"}
./old/server033-v1.75.2-30033.log:2023-03-23T02:06:58.506+0100 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "35.205.252.199:52090", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-03-26T00:31:30.275+0100 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "35.205.252.199:43274"}
./old/server033-v1.75.2-30033.log:2023-03-26T00:31:30.352+0100 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "35.205.252.199:43274", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-03-28T17:48:02.557+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.78.247.68:51322"}
./old/server033-v1.75.2-30033.log:2023-03-28T17:48:02.599+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.78.247.68:51322", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-03-30T04:15:41.899+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.78.247.68:44636"}
./old/server033-v1.75.2-30033.log:2023-03-30T04:15:41.934+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.78.247.68:44636", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-03-31T11:56:06.363+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.78.247.68:37570"}
./old/server033-v1.75.2-30033.log:2023-03-31T11:56:06.394+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.78.247.68:37570", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-01T08:42:23.282+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET", "Offset": 0, "Size": 512, "Remote Address": "90.94.212.9:33704"}
./old/server033-v1.75.2-30033.log:2023-04-01T08:42:23.298+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET", "Offset": 0, "Size": 0, "Remote Address": "90.94.212.9:33704", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-01T21:29:02.394+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.78.247.68:53558"}
./old/server033-v1.75.2-30033.log:2023-04-01T21:29:02.394+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.78.247.68:53558", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-03T04:04:11.358+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.78.247.68:44364"}
./old/server033-v1.75.2-30033.log:2023-04-03T04:04:11.394+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.78.247.68:44364", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-04T18:15:54.462+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.22.204.140:38784"}
./old/server033-v1.75.2-30033.log:2023-04-04T18:15:54.515+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.22.204.140:38784", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-06T08:52:35.868+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.22.204.140:53874"}
./old/server033-v1.75.2-30033.log:2023-04-06T08:52:35.890+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.22.204.140:53874", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-07T18:51:30.927+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.22.204.140:54948"}
./old/server033-v1.75.2-30033.log:2023-04-07T18:51:30.960+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.22.204.140:54948", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
./old/server033-v1.75.2-30033.log:2023-04-09T06:08:08.417+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.22.204.140:50576"}
./old/server033-v1.75.2-30033.log:2023-04-09T06:08:08.428+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.22.204.140:50576", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-10T18:32:17.383+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.22.204.140:56810"}
server033-v1.76.2-30033.log:2023-04-10T18:32:17.410+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.22.204.140:56810", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-11T01:17:41.167+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 256, "Remote Address": "34.22.204.140:37430"}
server033-v1.76.2-30033.log:2023-04-11T01:17:41.168+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 256, "Size": 0, "Remote Address": "34.22.204.140:37430", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-11T19:16:57.308+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.22.204.140:42206"}
server033-v1.76.2-30033.log:2023-04-11T19:16:57.344+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.22.204.140:42206", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-13T17:36:08.957+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.22.204.140:34254"}
server033-v1.76.2-30033.log:2023-04-13T17:36:09.005+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.22.204.140:34254", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-15T09:34:10.678+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.142.47.178:47302"}
server033-v1.76.2-30033.log:2023-04-15T09:34:10.708+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.142.47.178:47302", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
server033-v1.76.2-30033.log:2023-04-16T23:08:04.933+0200 INFO piecestore download started {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 256, "Remote Address": "34.142.47.178:44844"}
server033-v1.76.2-30033.log:2023-04-16T23:08:04.985+0200 ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT", "Offset": 0, "Size": 0, "Remote Address": "34.142.47.178:44844", "error": "file does not exist", "errorVerbose": "file does not exist\n\tstorj.io/common/rpc/rpcstatus.Wrap:75\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:650\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:251\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:61\n\tstorj.io/common/experiment.(*Handler).HandleRPC:42\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:124\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:114\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
root@server030:/disk102/storj/logs/storagenode# ls -l /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3h7h6uxttsgwxjse37p2mredrunihsd45un6meqyk4kzvromq*
ls: cannot access '/disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3h7h6uxttsgwxjse37p2mredrunihsd45un6meqyk4kzvromq*': No such file or directory
root@server030:/disk102/storj/logs/storagenode# ls -l /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3*
-rw------- 1 root root 2319872 Dec 13 02:15 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d34pll52fm5limhbnqbnftgswgo4e4nehjytnyhv2cjxt4plba.sj1
-rw------- 1 root root 290816 Mar 23 01:54 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3ax7t6dw4fige5egpw5d4z5vpbkedce32s7tbcedx3tqmeqaq.sj1
-rw------- 1 root root 580608 Mar 27 16:44 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3g2alwafqh5zr2fbnh2cebmyzrggol5kydkapdja3bwtftgeq.sj1
-rw------- 1 root root 2319872 Jun 17 2022 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3hul4s2b4snv4ancwvrdk3s6idpfhfch2p22dmzfi52vmq3aa.sj1
-rw------- 1 root root 33536 May 12 2022 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3va2mnco4dx3biicqcjqx3c4p3povpjc45b43mzltv6bhtjva.sj1
-rw------- 1 root root 399616 Aug 21 2022 /disk254/storj/data/server033-28967/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/rf/d3zdsly3mv7moahw5mqary56bzfw6753w5qwh4y3lk3sxruyia.sj1
**Describe the results you expected:**
Satellite should just GET_AUDIT the file once, and if the file is missing, then lower the AUDIT score and never audit the file again.
**Describe the results you received:**
For the last ~30 days I've noticed up to 20 x GET_AUDIT fails for the same piece ID despite the file does not exist.
root@server030:/disk102/storj/logs/storagenode# grep "download failed" server033-v1.76.2-30033.log ./old/server033* | grep "GET_AUDIT" | grep "file does not exist" | awk -F 'Piece ID' '{print $2}' | awk -F'"' '{print $3}' | sort | uniq -c | sort -nr | head -n 45
20 RFD3H7H6UXTTSGWXJSE37P2MREDRUNIHSD45UN6MEQYK4KZVROMQ
19 Z7W7V75DH7FB7WWKAA2LP4HH5D4PLSN3XCU7GESU7S4DLAV2RCGA
19 WX6YXFXJAB6EA5INYG6HQ4CC7S3O6NBUGHON6WOMXGNBEU4OFJNQ
19 V3XP74MYEGCJSVUZQD2TK4BG735IPZBOOIQBDX4MAVK3XWUA43PA
19 OIY4YQFU7ZRSSMMUQB6YSVXDYY2SE3OK5RBLXJ3AQN3JZMSXFOAA
19 NVM4Z3SKLZYIT3W4D63G5NY5Q7EBW7CXDCVXD5GVN5SFHO5XD2BA
19 NV4WP5PTZDDTPI62PHYNGYUAHW44CUAOEFPESSMSLSM77VFY7ZVQ
19 DXL3PZ75X2WFFKC5MUW6WH55PKGDCLYJBYAXAEPFWZSF3AL2MXPQ
19 DK2WWZMXVM3PREY2UCEIYZYO7QJQJXJ4XS2XDQQVVXK76G657Z2A
18 FPNQWWAV6THTTBMYCRY5MWY55EGJJQ5WW7LSAYXOCJD52FZ46SSQ
16 6T3XHWQ27JJ2I4MKUPMC5KFFYD76U3TJF3MZJY2VWBYNHLYDKHCA
14 VLXBWCY6CDQUAI5EBV2JTEPD2CAFVN5ZGJLIXN3BGH5REA3D4AQA
14 PGSASXLJ5FSM4RGADYMXY2IC2FAYDTGPHQ2UPRKD4TUBLV62UMMA
14 66ANXOTMA5CMSMPFVDGWJTHCIIOCWGCFFFVO7X65Z7X4VO3BF32Q
11 WXYJPKOVE5RI3RSPHPWWAUQBFSSTB3PXI2LXNDFGCEXHAKAPKIEQ
11 EF5PSNYTKW4N7BVZT5WNETBFE4OE6MJC7O2X3CWUDOHPX5Z22F2A
9 XUCUMYHTCWFSEJCYY7LMQOOIGLTKJ7RFITTKPO3FDUEWEZJSWC3Q
8 GWW7NPDJWJ2G4GCOKVQXJGZGAQIRCG6C6C43LPZZMHIUXCCRLL5Q
8 6IYLJXGIBVVACSPU2C4ABYSMHPENG7TFGBGM6TTJ764XOAVU7DXA
7 OOFGPT6C5UFLQ42QQGPV6I5IYGPKZARW7V74OGSUINX3TWVAAVDA
7 ERDOU6B5SVLNL4UA2XRNTL4AQXM5XEF4RNLHQHLJE3KRUUDMBBBQ
7 EFXJE2JBC6ZNCYHO2XLG2E5EIZ2YJDP6VIA6MVI5JMBPTSLDDR2A
7 6IBFCDHS5TKWTTQYI57FCCWVITOWME4RZ54EVKHQPX4C3Z3I2SRA
6 N6Q6DTNYU3RGKUSFXYLXFO6RMERYJ3F65RMM45D22SYVEPBFEA3Q
6 4SM5DAUXIP5ZTXZL2KDNXPNQDDJQ4GILWILNXXA3SJ4L3YSOMRRA
5 6IMDUYQHHAQHWA4AMH2HZMSVX2GF7HNQPKQQ23L3WPU3EHSQG4UQ
5 5UZM6DCUDG4GPQ25R7ZMN3JX4WTHF3Y6ZJYLNZF2QQNQXPI2ZLOA
4 WYZ3TC6AXEQQD6UX55BLETJBRC6QNIYAAIC5OO44LNAMB3RA5B4A
4 WXF54OLKTPNRG65MK44W7BB3TUQBG64O7BUFUEXQABPST74ZHBKA
4 RFGO5RPPRSULQYTUHP6X6FBI37O3WGWDRSSXLZLTGAKASZRQS6LQ
4 K4VSTGMI7DVDEE3E27NWV6LX7VKVIPTFYQHKEIEAOF6MGVHXROZQ
4 DXCWJVLKINCHH3QHFIDQWBYFVRV5MWBOPBVK7BOZLG43B6YZCBGA
4 3IG2FARIO6NPXKA6YASOY5ORAZUZB757K77ZMK22ULAX74G4UDJQ
3 YLTZ56GIYNIKDAS5Y6T5TIIOMYRNBFF67P6IGK4ORMRKX3RCX54Q
3 PK743XYAQFWWG3T52TJW2DLCEVKXPJJPWUH26YMEYJM3DEAY4LNA
3 6TVAUSEJSTOURMNXW3DCG5EAF2EMW5WE67UVVOPHNYIM2DPC3IGQ
3 66JVN63QZQJCYYUW6ZOCULADGDTA4OD3DXQUQ4FKRPGGA6FGO6GQ
2 YOEDGQBMI45RK66YG4SDL62HMQLC7YBPUYCFWDH57DVT4EVWEVKQ
2 XUXBOG2WH6WN4ZVPDGBWTS5SBQ6DITXE3UJY6CYWEB6F4QEXBV3Q
2 U6NHJAFJZ2J4GFE7LUY2UGQRQWTWJTLV5MJ5IOLK5WHFLEJ2EL6A
2 JEP756HNSFDL6WEHFZGUZ3B5G5LUOOHYB4XLCPJEAOBF3VLEJDQQ
2 HHBRBJBKZVV76SWIBOJDDCKCT6A6UD5XNBR4SAWA6VEQ3KHXYWWA
2 HH7ZPO74TXHVE4LWSUDF2AM65BDDQDFQVX2NSD4PNDAMTQ4NJBAQ
2 GWSY53NS4HLVKFTLWYZNRZH2L6DL664AJ3EV2WLK6ODAYXR6WHGQ
2 FEVPFE6COE2I6D2MJZYHGHULMI4OMT2WUG57LDHT6QURBLIWGL3A
Th3Van.dk
