Hello @vivaldi,
- Stop the storagenode
- Remove
heldamount.db
, piece-expiration.db
, piece_expiration.db
and pricing.db
- Execute either with a local sqlite3 (v3.25.2 or later) or with a docker version (you can take it from https://support.storj.io/hc/en-us/articles/360029309111), replace the
/path/to/
to the actual path:
sqlite3 /path/to/heldamount.db
- When you see a
sqlite>
prompt execute this script:
CREATE TABLE versions (version int, commited_at text);
CREATE TABLE paystubs (
period text NOT NULL,
satellite_id bytea NOT NULL,
created_at timestamp NOT NULL,
codes text NOT NULL,
usage_at_rest double precision NOT NULL,
usage_get bigint NOT NULL,
usage_put bigint NOT NULL,
usage_get_repair bigint NOT NULL,
usage_put_repair bigint NOT NULL,
usage_get_audit bigint NOT NULL,
comp_at_rest bigint NOT NULL,
comp_get bigint NOT NULL,
comp_put bigint NOT NULL,
comp_get_repair bigint NOT NULL,
comp_put_repair bigint NOT NULL,
comp_get_audit bigint NOT NULL,
surge_percent bigint NOT NULL,
held bigint NOT NULL,
owed bigint NOT NULL,
disposed bigint NOT NULL,
paid bigint NOT NULL,
PRIMARY KEY ( period, satellite_id )
CREATE TABLE payments (
id bigserial NOT NULL,
period text,
amount bigint NOT NULL,
receipt text,
notes text,
PRIMARY KEY ( id )
.exit
- The next database
sqlite3 /path/to/piece_expiration.db
- When you see the
sqlite>
prompt, execute this script:
CREATE TABLE piece_expirations (
satellite_id BLOB NOT NULL,
piece_id BLOB NOT NULL,
piece_expiration TIMESTAMP NOT NULL, -- date when it can be deleted
deletion_failed_at TIMESTAMP, trash INTEGER NOT NULL DEFAULT 0,
PRIMARY KEY (satellite_id, piece_id)
CREATE INDEX idx_piece_expirations_piece_expiration ON piece_expirations(piece_expiration);
CREATE INDEX idx_piece_expirations_deletion_failed_at ON piece_expirations(deletion_failed_at);
CREATE INDEX idx_piece_expirations_trashed
ON piece_expirations(satellite_id, trash)
WHERE trash = 1;
.exit
- The next database
sqlite3 /path/to/pricing.db
- When you see a
sqlite>
CREATE TABLE pricing (
egress_bandwidth_price bigint NOT NULL,
repair_bandwidth_price bigint NOT NULL,
audit_bandwidth_price bigint NOT NULL,
disk_space_price bigint NOT NULL,
PRIMARY KEY ( satellite_id )
.exit
- Start the storagenode
- Check your logs
