Filewalker DB suddenly locked - node stopped to work
Hi,
Suddenly my node stopped to work (no changes on my setup for several months).
I have not able to recover node, by restarting or reconfiguring.
Also my node has been a bit unstable for long time. Quite often QUIC is Misconfigured even if no changes. But it recovers after awhile. So online statistics are worse as it should be (only few short maintenance breaks within couple last months)
2024-04-17T05:00:59Z ERROR failure during run {“Process”: “storagenode”, “error”: "Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file "config/storage/garbage_collection_filewalker_progress.db" failed: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:364\n
Error: Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file “config/storage/garbage_collection_filewalker_progress.db” failed: database is locked
2024-04-17 05:00:59,906 INFO exited: storagenode (exit status 1; not expected)
Any ideas how get this node working?
Welcome to the forum @JeanS !
Can you move your dbs to SSD ?
Actual node is running on Proxmox → Ubuntu Desktop 22.04. This is NVME drive.
And data is stored to TrueNAS and it is using normal 3.5" HDDs
This is command that I am using to start node.
-p 28967:28967/tcp
-p 28967:28967/udp
-p 127.0.0.1:14002:14002
-e WALLET=“0x83b624C08xxxxxxxxx1b55848”
-e EMAIL="xxx@gmail.com"
-e ADDRESS=“js-storj.ddns.net:28967
-e STORAGE=“6TB”
–user $(id -u):$(id -g)
–mount type=bind,source=“/home/storj/storagenode”,destination=/app/identity
–mount type=bind,source=“/media/storj/TrueNAS/StorJ_Data”,destination=/app/config
How is the 3.5" physicaly connected ?
May you have a timeout “fatal” error unnoticed?
Both StorJ (Ubuntu) and TrueNAS Scale are running as VMs on same Proxmox server.
Storj user data is accessible via SMB Share of this TrueNAS Scale. TrueNAS Storage consisting 10*3.5 HDDs (RaidZ)
As both VMs are physically in same server, so data is accessed just via Proxmox virtual bridge.
Read and write speeds should be better than directly attached harddrive, but delays may be higher → could that cause issue?
To add: After restart I am not able to access anymore to StorJ GUI, so node is not working at all.
Node is on constant stop & start loop:
2024-04-17 12:53:54,489 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
944
2024-04-17 12:53:54,489 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
945
2024-04-17T12:54:03Z ERROR failure during run {“Process”: “storagenode”, “error”: "Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file "config/storage/garbage_collection_filewalker_progress.db" failed: database is locked\n\tstorj.io/
024-04-17 12:54:03,401 INFO exited: storagenode (exit status 1; not expected)
962
2024-04-17 12:54:04,405 INFO spawned: ‘storagenode’ with pid 40
963
2024-04-17 12:54:04,405 WARN received SIGQUIT indicating exit request
964
2024-04-17 12:54:04,405 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
965
2024-04-17T12:54:04Z INFO Got a signal from the OS: “terminated” {“Process”: “storagenode-updater”}
966
2024-04-17 12:54:04,408 INFO stopped: storagenode-updater (exit status 0)
967
2024-04-17 12:54:04,409 INFO stopped: storagenode (terminated by SIGTERM)
968
2024-04-17 12:54:04,410 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
969
2024-04-17 12:54:05,180 INFO Set uid to user 0 succeeded
970
2024-04-17 12:54:05,188 INFO RPC interface ‘supervisor’ initialized
=> then it starts again
I renamed this garbage_collection_filewalker_progress.db and now node cannot even read identity.cert
2024-04-17T13:18:43Z FATAL Error loading identity. {“Process”: “storagenode-updater”, “error”: “file or directory not found: open identity/identity.cert: permission denied”,
I think something is corrupted / messed up on my Ubuntu or Docker. I’ll try to do complete reinstallation; delete current VM and then new ubuntu installation etc. But maybe it is too late, now offline 12+ hours
This is your problem. You can’t use Storj with data over SMB/NFS etc. because the SQLite database locks don’t work reliably over network protocols and this could lead to database corruption. Why not run Storj on the TrueNAS Scale VM?
It is not to late. You can always delete all databases. If all databases are missing the node creates them new. You will lose the history in the dashboard, everything else will be restored.
As others have said, SMB at the Linux / Windows level isn’t supported with Sqlite…
I don’t understand why you have TrueNas on Proxmox - there are many issues with how the disks are passed through, they have to be raw devices, that can’t be done in the GUI, it’s like you want to build a slow disk system… Also Proxmox is native ZFS, you could of built the pool directly in Proxmox and skipped TrueNas :confused:
However. you have the ZFS pool in TrueNas, so a better option is to export access to the pool directly into Proxmox, then create the Virtual Disks natively.
In Proxmox, under the Datacentre view for Storage add External providers… you can add SMB pointing to your TrueNas Share, and mark it for VM disk storage - Then on the Storj Machine, you can create a new Vdisk, and locate it on the share.
In the Storj Linux OS, if you do a lsblk, you will see the new disk - add it to LVM, setup the VG / LV and format it to ext4, mount it… then use rsync to move the data over.
SMB isn’t suited to Disk images though, it can be slow…
Better option is to export the ZFS pool via ZFS over iSCSI, then map that into the Datacentre Storage, but that is way outside the scope of this forum to setup…
Alternatively, and much more simple, Setup ISCSI on the TrueNas box, export a disk Image, then again map that in the Datacentre view using just iSCSI.
CP
I created StorJ VM directly to TrueNAS and created ZVol for this VM, thanks on tips!
I tried to install TrueNAS directly to bare HW, but I did not like TrueNAS Virtualization (compared to Proxmox). Also various problems on networking and GPU passthrough issues.
Edit: I tried this about 6months ago. So StorJ was working about 6months on this VM + SMB setup, except random QUIC issues.
So I returned to use Proxmox and run TrueNAS as a VM.
HBA pcie cards are passthrough to TrueNAS, so all harddrives are ‘directly’ connected to TrueNAS.
I hope this setup works better than previous.
The network filesystems are not supported.
This will not work. The “database is locked” means that the access is locked, so the data location is slow (and this is expected when you use any network filesystems, this is why they are not supported).
Seems you messed up something, if it lost access. However, again, since you use a network filesystem it stopped to work.
Please either use a virtual disk for your VM, or pass thru, or at least iSCSI, or even better - move out storagenode from VMs and run it as a container directly on your Proxmox.
I’m also having issues with similar error messages. I too was storing my databases over SMB on TrueNAS and have been running that way for years with ZERO issues. Now suddenly I’m having trouble. I’ve tried moving the databases to the host VM running on Proxmox but I still can’t get my node back online.
2024-04-30 02:16:14,045 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-04-30 02:16:14,045 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-04-30 02:16:14,045 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2024-04-30T02:16:23Z    ERROR   failure during run      {"Process": "storagenode", "error": "Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file \"config/storage/garbage_collection_filewalker_progress.db\" failed: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:364\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:341\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:316\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:281\n\tmain.cmdRun:65\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:267", "errorVerbose": "Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file \"config/storage/garbage_collection_filewalker_progress.db\" failed: database is locked\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabase:364\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openExistingDatabase:341\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).openDatabases:316\n\tstorj.io/storj/storagenode/storagenodedb.OpenExisting:281\n\tmain.cmdRun:65\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:267\n\tmain.cmdRun:67\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tmain.main:34\n\truntime.main:267"}
Error: Error opening database on storagenode: database: garbage_collection_filewalker_progress opening file "config/storage/garbage_collection_filewalker_progress.db" failed: database is locked
        main.cmdRun:65
        main.main:34
        runtime.main:267
SQLite over SMB is a horrible idea. Don’t do that. Read section 2.1 here: How To Corrupt An SQLite Database File
Storagenode over SMB is not supported either. The only exception is iSCSi.
Run storagenode directly on truenas.
but it worked for ages?
Well, even broken clock show correct time twice a day. It broke now as the traffic picked up and all the concurrency issues got a better chance to manifest themselves.
Move storagenode to TrueNAS.
Hello @Derezzer,
Any network filesystems are not supported, include but not limited to SMB/CIFS, NFS, SSHFS, etc.
The fact that it somehow worked before doesn’t mean that it would work in the future.
I agree with @arrogantrabbit , you need to move your node to the TrueNAS directly. Preferable - as a container, not a VM.
I moved StorJ to TrueNAS VM and using TrueNAS ZVol as a disk. No issues since, and logs are having only INFO traces. I installed also Portainer, so it is easy to follow status of storagenode.
Whole Proxmox where TrueNAS was running ‘died’ few days ago, and I got some downtime, but this is not related to StorJ/TrueNAS directly.
But why wasting resources on VM? The container has much less overhead, you likely can run it as a container on Proxmox directly…
