I recently enabled the space-filewalker after the node automatically updated to 109.2. And I found that the filewalker failed. Not sure how can I resolve that?
There are some post mentioned that can disable ‘lazy’ mode but I am not sure where I can disable it.
both the startup scan and lazy filewalker are set as true in the config.
- --storage2.piece-scan-on-startup true
- --pieces.enable-lazy-filewalker true
2024-07-31T09:07:01Z ERROR pieces used-space-filewalker failed {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Lazy File Walker": false, "error": "filewalker: context canceled", "errorVerbose": "filewalker: context canceled\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkSatellitePieces:74\n\tstorj.io/storj/storagenode/pieces.(*FileWalker).WalkAndComputeSpaceUsedBySatellite:79\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:721\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
I have the same issue with the same version
If you run your node on Windows, then it seems to be a known issue:
i do a shutdown from services but i get this
2024-07-19T18:37:02+03:00 INFO Stop/Shutdown request received.
2024-07-19T18:37:02+03:00 INFO lazyfilewalker.trash-cleanup-filewalker subprocess exited with status {“satelliteID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “status”: 1, “error”: “exit status 1”}
2024-07-19T18:37:02+03:00 ERROR pieces:trash emptying trash failed {“error”: “pieces error: lazyfilewalker: exit status 1”, “errorVerbose”: “pieces error: lazyfilewalker: exit sta…
You need to disable the lazy mode.
It is on Debian. Btw, how to disable lazy mode?
marvinso1978:
–pieces.enable-lazy-filewalker true
Change this:
to this:
pieces.enable-lazy-filewalker false
I thought that if I turn this to False, then no filewalker would be run
No, there is an other option, you can controll the used space file walker at startup with these:
storage2.piece-scan-on-startup true - when your node starts, used space file walker will start as well
or
storage2.piece-scan-on-startup false - when your node starts, used space file walker will NOT start
For the lazy filewalker:
pieces.enable-lazy-filewalker false - normal filewalker will be used
or
pieces.enable-lazy-filewalker true - lazy filewalker will be used
Alexey
August 2, 2024, 4:24am
8
In the linked thread the failed filewalker is a consequence of a “slow shutdown”, which is usually happen because of an Unrecoverable and/or FATAL error or the shutdown request somewhere earlier.
In the linked case it’s
Something is stopped their node.
