i am on debian , and i have the latest filezilla version , there is no storj protocol in the program and when i try to enable it using
filezilla ./configure --enable-storj
it says Unknown long option ‘enable-storj’
could someone help please i need to use filezilla to upload multiple files and directories at once.
You need to install the newest filezilla and its easier to use the GUI on linux to use storj.
i do have the latest filezilla version
I will test on one of my linux servers and see if its the same. I tested it once but it was a while ago.
Yes it is there.
You might also want to refer to our setup guides for Filezilla native integration which works with the free version, and the Filezilla Pro Integration Guide.
You need to download FileZilla from https://filezilla-project.org/download.php.
In package managers FileZilla comes without Storj library for some reason.
