I have greated some buckets with the browser. Then I generated access to the buckets also with the webgui.
After a backup with duplicati to a bucket was greated, I tried to connect to the bucket with the filezilla. There are no files showen(only the different buckets). Also with the androidapp Bucketanywhere.
To remove a bucket you should use rb instead of rm. You can use the --force flag to remove non-empty buckets. Alternatively you can use rm with the --encrypted flag to remove encrypted objects.
Make sure to always keep your pass phrases stored somewhere safe. Without them you can never get access to the original objects again. All you can do is delete those objects.
I can’t really answer that. It’s really dependent on your project requirements. But I can imagine that you might want to use different passphrases for different users. Like if you use Storj as a backend for an app you could use a pass phrase derived from the users password to encrypt their files and ensure that you as a developer don’t even have access to their files.
If it’s just your personal backups, then yeah, one passphrase is probably easiest. But I think having it be possible to use all different passphrases opens up a lot more options.
