On my newest node first audit failed. Bad luck I guess but it made node audit score 0%(instant DQ).
I know hardware and internet are both good and node should not be disqualified based on 1 failed audit.
It is slow node in europe and this satellite us-central-1 in not sending lots of data to my other nodes so it is no big deal but I wanted to share this with you all.
12uNjWTn9YdiZspxzV6bSdtTah4cPvX6EVzXxrNwE7efbmnuPEt
Node ID in case someone from Storj team wants to look at this on satellite database.
I had to dump in to file using “script” command so I can search thru this huge log.
According to log there is no failed audits. After “download started GET_AUDIT” there is “Downloaded GET_AUDIT” every time.
When I received DQ e-mail my node still reported 0 total audits for that satellite. It showed up after few minutes when I checked again.
Then it was a 4x timeout to provide a small fraction of the piece for audit with 5 minutes wait time.
I would check the setup if it were me, seems your system becomes unresponsive for some reason.
