For some reason my total disk space is 0.
2021-03-14T16:14:36.567Z INFO bandwidth Performing bandwidth usage rollups
2021-03-14T16:14:36.567Z INFO Node xxx started
2021-03-14T16:14:36.567Z INFO Public server started on [::]:7777
2021-03-14T16:14:36.568Z INFO Private server started on 127.0.0.1:7778
2021-03-14T16:14:36.568Z INFO failed to sufficiently increase receive buffer size (was: 224 kiB, wanted: 2048 kiB, got: 448 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details.
2021-03-14T16:14:36.568Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {"bytes": 357416779776}
2021-03-14T16:14:36.568Z INFO trust Scheduling next refresh {"after": "5h54m13.634677307s"}
2021-03-14T16:14:36.568Z ERROR piecestore:monitor Total disk space is less than required minimum {"bytes": 500000000000}
2021-03-14T16:14:36.568Z ERROR services unexpected shutdown of a runner {"name": "piecestore:monitor", "error": "piecestore monitor: disk space requirement not met", "errorVerbose": "piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(
*Service).Run:123\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-03-14T16:14:36.569Z ERROR nodestats:cache Get pricing-model/join date failed {"error": "context canceled"}
2021-03-14T16:14:36.570Z ERROR gracefulexit:blobscleaner couldn't receive satellite's GE status {"error": "context canceled"}
2021-03-14T16:14:36.571Z ERROR piecestore:cache error during init space usage db: {"error": "piece space used error: context canceled", "errorVerbose": "piece space used error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).Init:73\n
\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:75\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2021-03-14T16:14:36.571Z ERROR gracefulexit:chore error retrieving satellites. {"error": "satellitesdb error: context canceled", "errorVerbose": "satellitesdb error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:100\n\tstor
j.io/storj/storagenode/gracefulexit.(*service).ListPendingExits:89\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run.func1:53\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run:50\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:
2021-03-14T16:14:36.572Z ERROR collector error during collecting pieces: {"error": "piece expiration error: context canceled", "errorVerbose": "piece expiration error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceExpirationDB).GetExpired:39\n\
tstorj.io/storj/storagenode/pieces.(*Store).GetExpired:520\n\tstorj.io/storj/storagenode/collector.(*Service).Collect:88\n\tstorj.io/storj/storagenode/collector.(*Service).Run.func1:57\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenode/collector.(*Service).Run:53\n\tst
2021-03-14T16:14:36.572Z ERROR bandwidth Could not rollup bandwidth usage {"error": "sql: transaction has already been committed or rolled back"}
Error: piecestore monitor: disk space requirement not met
2021-03-14T16:14:46.404Z INFO Operator email {"Address": "xxx"}
2021-03-14T16:14:46.404Z INFO Operator wallet {"Address": "xxx"}
2021-03-14T16:14:48.778Z INFO Telemetry enabled {"instance ID": "xxx"}
2021-03-14T16:14:49.011Z INFO db.migration Database Version {"version": 51}
2021-03-14T16:14:50.916Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock.
2021-03-14T16:14:51.764Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock.
2021-03-14T16:14:51.764Z INFO bandwidth Performing bandwidth usage rollups
2021-03-14T16:14:51.765Z INFO Node xxx started
2021-03-14T16:14:51.765Z INFO Public server started on [::]:7777
2021-03-14T16:14:51.765Z INFO Private server started on 127.0.0.1:7778
2021-03-14T16:14:51.765Z INFO failed to sufficiently increase receive buffer size (was: 224 kiB, wanted: 2048 kiB, got: 448 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details.
2021-03-14T16:14:51.767Z INFO trust Scheduling next refresh {"after": "6h56m3.654695603s"}
2021-03-14T16:14:51.770Z WARN piecestore:monitor Disk space is less than requested. Allocated space is {"bytes": 357416742912}
2021-03-14T16:14:51.770Z ERROR piecestore:monitor Total disk space is less than required minimum {"bytes": 500000000000}
2021-03-14T16:14:51.770Z ERROR services unexpected shutdown of a runner {"name": "piecestore:monitor", "error": "piecestore monitor: disk space requirement not met", "errorVerbose": "piecestore monitor: disk space requirement not met\n\tstorj.io/storj/storagenode/monitor.(
2021-03-14T16:14:51.771Z ERROR nodestats:cache Get pricing-model/join date failed {"error": "context canceled"}
2021-03-14T16:14:51.774Z ERROR piecestore:cache error during init space usage db: {"error": "piece space used error: context canceled", "errorVerbose": "piece space used error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).Init:73\n
2021-03-14T16:14:51.781Z ERROR gracefulexit:blobscleaner couldn't receive satellite's GE status {"error": "context canceled"}
2021-03-14T16:14:52.704Z ERROR gracefulexit:chore error retrieving satellites. {"error": "satellitesdb error: context canceled", "errorVerbose": "satellitesdb error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits.func1:103\n
\tstorj.io/storj/storagenode/storagenodedb.(*satellitesDB).ListGracefulExits:115\n\tstorj.io/storj/storagenode/gracefulexit.(*service).ListPendingExits:89\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).Run.func1:53\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/storj/storagenod
e/gracefulexit.(*Chore).Run:50\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:81\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:80\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
