Im troubleshooting on my Node connection.
I’ve followed all instructions and opened ports on both PC forewall and router.
But still when i check via check open node ports it says all ports closed.
netstat -aon shows all ports to listening both on PC and router
oh … guess my IP is only static on local network …
and not external
if i run my port test it shows an IP = external IP it not the one i use in setup. Bu i also guess the setup is to always point the ports towards PC on local network, right ?
Not possible to add external IP as valid adress for Internal host on portforwarding.
If external server tries to acces my point, I guess it doesent matter what external IP i got. But behind my router / firewall it matters a lot that connection is pointet to PC with docker running. Thats why i trough PI guide setup an static IP for my PC.
HI, problem solved:
Test program is error flaved. Everything regarding connection was OK.
Only issue i had left was PI program continuing to stay whithe trying to establish connection.
This issue solved by adding “containerFlavor”:“stellar” to the file user-preferences.json
Herafter, restart computer and it works on first try.
