Hopefully someone can help me out or point me in the right direction.
I have decided to run storagenode.
I do have Truenas that I Have approx 16tb of memory unused.
Because Network storage is not recommended can not install it on my windows server.
And I would prefer to run the node from Truenas jail.
I found binaries here for freebsd: Releases · storj/storj · GitHub but have zero ideas how to run everything.
So was hoping that someone could point me in the right direction to some guides or step by step setup how to use correctly binaries.
Thank you for your advice. I just tried ISCSI approach and still got the same error when running the installation. ‘There is a problem with this Windows installer package Contact your support personnel or package vendor.’
I have two storagenodes running as jails on my TrueNAS server, maybe I should write a guide sometime.
Each are configured using their own VNET and IP address. On the first I have separate vdevs/mountpoints for storage, database and logs and on the second just one vdev/mointpoint containing all three. You can make it as simple/complicated as you like.
As this isn’t a docker environment you need to download and run the storagenode freebsd binary from here: Releases · storj/storj · GitHub
I’ve installed and configured supervisord to handle restarts and similarly logrotate to rotate the node log.
For ease I used my windows laptop to generate the identities as it has better CPU resources than my NAS.
BSD doesn’t like you replacing running binaries so I wrote a script run by cron that periodically checks for updates and downloads them automatically and then notifies me that there’s a new version downloaded and ready.
I have another script I run manually when I’m ready, that stops the supervisord storagenode service, replaces the current binary and restarts the service.
I can share more details if it’s something you’re interested in.
Indeed you should run storagenode with the setup command with the appropriate args for your install. Without arguments the default is to create the config at $HOME/.local/share/storj/storagenode/config.yaml,
look for the identity information in $HOME/.local/share/storj/identity/storagenode/ and store files at $HOME/.local/share/storj/storagenode/storage/
I personally keep the default locations for the config and identity and customize the storage.path in the config file once it has been created (as well as other settings). I also use a dedicated storj user and group to run the storagenode.
These are the config options I use:
# ensures console is accessible from your network on port 14002
console.address: 0.0.0.0:14002
# address and port to find your server
contact.external-address: "node.wibble.com:28967"
# ensure the log directory is owned by the user running the storagenode
log.output: "/var/log/storj/node.log"
# the email address used by storj to contact you with updates etc.
operator.email: "user@wibble.com"
#only if you opt in to zksync
operator.wallet-features: ["zksync"]
operator.wallet: "<wallet string starting 0x>"
# the port used for storage access, you should forward traffic on both UDP and TCP from contact.external-address to this port
server.address: :28967
storage.path: /mnt/storj/storagenode/storage
storage.allocated-disk-space: 750 GB
To avoid a warning about not being able to increase UDP buffer size I also the the following tunable in TrueNAS itself: kern.ipc.maxsockbuf 30146560 SYSCTL
./storagenode help
StorageNode
Usage:
storagenode [command]
Available Commands:
config Edit config files
dashboard Display a dashboard
diag Diagnostic Tool support
exit-satellite Initiate graceful exit
exit-status Display graceful exit status
help Help about any command
issue-apikey Issue apikey for mnd
run Run the storagenode
setup Create config files
version output the version's build information, if any
Flags:
--color use color in user interface
--config-dir string main directory for storagenode configuration (default "/home/pi/.local/share/storj/storagenode")
--db.conn_max_lifetime duration Maximum Database Connection Lifetime, -1ns means the stdlib default (default 30m0s)
--db.max_idle_conns int Maximum Amount of Idle Database connections, -1 means the stdlib default (default 1)
--db.max_open_conns int Maximum Amount of Open Database connections, -1 means the stdlib default (default 5)
--debug.addr string address to listen on for debug endpoints (default "127.0.0.1:0")
--debug.trace-out string If set, a path to write a process trace SVG to
--defaults string determines which set of configuration defaults to use. can either be 'dev' or 'release' (default "release")
-h, --help help for storagenode
--identity-dir string main directory for storagenode identity credentials (default "/home/pi/.local/share/storj/identity/storagenode")
--log.caller if true, log function filename and line number
--log.development if true, set logging to development mode
--log.encoding string configures log encoding. can either be 'console', 'json', or 'pretty'.
--log.level Level the minimum log level to log (default info)
--log.output string can be stdout, stderr, or a filename (default "stderr")
--log.stack if true, log stack traces
--metrics.addr string address(es) to send telemetry to (comma-separated) (default "collectora.storj.io:9000")
--metrics.app string application name for telemetry identification (default "storagenode")
--metrics.app-suffix string application suffix (default "-release")
--metrics.instance-prefix string instance id prefix
--metrics.interval duration how frequently to send up telemetry (default 1m0s)
--tracing.agent-addr string address for jaeger agent (default "agent.tracing.datasci.storj.io:5775")
--tracing.app string application name for tracing identification (default "storagenode")
--tracing.app-suffix string application suffix (default "-release")
--tracing.buffer-size int buffer size for collector batch packet size
--tracing.enabled whether tracing collector is enabled
--tracing.interval duration how frequently to flush traces to tracing agent (default 0s)
--tracing.queue-size int buffer size for collector queue size
--tracing.sample float how frequent to sample traces
An interesting thing is that I just install pm2 to auto launch the app and after full reboot the errors are gone. I won’t cycle the logs, not yet at least just to make sure everything is up and running, but this far everything
I used my Freenas system as well, didn’t know there were plugins/packages for it though. I just set up an ubuntu server VM and did the normal storj install within that, nothing special needed. Would be great if there was an official plugin to do it all though!
Still making my update scripts production ready. Will have them ready over the next week - you won’t get blocked before then…
Just about completed my update script that downloads updates when they are ready after a re-thought on how it should work (it has all the intelligence now). Now need to update my restart script that can now be stupid - it will only need to check if a file is different.
If you’re using PM2 then you’ll need to re-implement the more stupid restart script I’m working on…
We have the updater binary for FreeBSD as well. Would you like to give it a try? You would be the first guinea pig. There is a good chance that the updater will not work and if so I don’t think we are going to fix that any time soon. However, if we are lucky it might work just fine. So we should at least try it.
v1.43.0-rc is identical with v1.43.1. The rollout hasn’t finished yet. If you run the updater it might print out that an update is ongoing but your node needs to stay on the old version for a bit more time.
The updater might fail with updating itself because in the new release the updater binary for your OS is missing. If that happens just let me know and I can upload the binary to the new release as well. Before I do that I would like to know if you even get that far.
