FreeBSD storagenode-updater doesn't work properly
Yes please!
The motivation, at least for FreeBSD users, is to have custom updater working properly, because we gave up on waiting for the official updater to do the right thing. I’ve filed a bug, it was “fixed” and closed and it’s broken anyway.
Today i’m using a shell script that just downloads the most recent version as soon as it is available and properly manages correct service restart, but of course it’s not ideal, especially if a lot of people do the same.
With this web api I could make my script a bit more compliant with gradual rollout.
Ok, I wouldn’t like to hijack this thread, but it seems to be a simple fix for me:
https://review.dev.storj.io/c/storj/storj/+/13274
I don’t have freebsd, but I can cross compile a binary if you are open to test it…
This looks exactly right!
Lines 42-45 are now invalid — we’ll get there only if service name is empty, at which point it will attempt to kill a process with no name. Those probably shall be deleted.
I’m open to test it.
Ups, you are right. But in this case, I wouldn’t like to change the existing behavior. Let’s not break existing setup (if they exist…)
Created an updated version which supports --restart-method service. Can be useful later to adjust Linux restarts as well… (eg. support systemctl restart)
Here is the binary, if you are interested to test: storagenode-updater_freebsd_amd64 | Storj
(built from 930e83b94)
Sorry took a while to test this.
The updater is unable to determine current version:
2024-06-01T11:37:26-07:00	INFO	storagenode-updater/loop.go:18	Downloading versions.	{"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2024-06-01T11:37:26-07:00	INFO	storagenode-updater/update.go:22	Current binary version	{"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.104.5"}
2024-06-01T11:37:26-07:00	INFO	storagenode-updater/update.go:33	Version is up to date	{"Process": "storagenode-updater", "Service": "storagenode"}
2024-06-01T11:37:26-07:00	ERROR	storagenode-updater/loop.go:33	Error updating service.	{"Process": "storagenode-updater", "Service": "storagenode-updater", "error": "unable to determine binary version", "errorVerbose": "unable to determine binary version\n\tmain.binaryVersion:40\n\tmain.update:17\n\tmain.loopFunc:31\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tmain.cmdRun:138\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tmain.main:22\n\truntime.main:267"}
main.loopFunc
	/go/src/storj.io/storj/cmd/storagenode-updater/loop.go:33
	/go/pkg/mod/storj.io/common@v0.0.0-20240425113201-9815a85cbc32/sync2/cycle.go:99
main.cmdRun
	/go/src/storj.io/storj/cmd/storagenode-updater/cmd.go:138
	/go/pkg/mod/storj.io/common@v0.0.0-20240425113201-9815a85cbc32/process/exec_conf.go:393
	/go/pkg/mod/storj.io/common@v0.0.0-20240425113201-9815a85cbc32/process/exec_conf.go:411
	/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:983
	/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1115
	/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1039
	/go/pkg/mod/storj.io/common@v0.0.0-20240425113201-9815a85cbc32/process/exec_conf.go:112
	/go/pkg/mod/storj.io/common@v0.0.0-20240425113201-9815a85cbc32/process/exec_conf.go:77
main.main
	/go/src/storj.io/storj/cmd/storagenode-updater/main.go:22
runtime.main
	/usr/local/go/src/runtime/proc.go:267
Executed as:
/usr/local/bin/storagenode-updater run \
    --config-dir "/mnt/storagenode/config" \
    --identity-dir "/mnt/storagenode/identity/storagenode"  \
    --binary-location "/usr/local/bin/storagenode"  \
    --service-name  "storagenode" \
Full logs
storagenode_updater.log
root@test-updater:~ # cat /var/log/storagenode_updater.log
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:318	Configuration loaded	{"Process": "storagenode-updater", "Location": "/mnt/storagenode/config/config.yaml"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "contact.external-address"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "server.address"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.wallet"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage2.database-dir"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "healthcheck.details"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "console.address"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "healthcheck.enabled"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "operator.email"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "server.private-address"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2024-06-01T11:10:06-07:00	INFO	process/exec_conf.go:328	Invalid configuration file key	{"Process": "storagenode-updater", "Key": "storage.path"}
2024-06-01T11:10:06-07:00	INFO	process/tracing.go:73	Anonymized tracing enabled	{"Process": "storagenode-updater"}
2024-06-01T11:10:06-07:00	DEBUG	tracing collector	monkit-jaeger@v0.0.0-20240221095020-52b0792fa6cd/thrift.go:149	started	{"Process": "storagenode-updater"}
2024-06-01T11:10:06-07:00	DEBUG	process/debug.go:39	debug server listening on 127.0.0.1:54783	{"Process": "storagenode-updater"}
2024-06-01T11:10:06-07:00	INFO	storagenode-updater/cmd.go:119	Running on version	{"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v0.0.0"}
2024-06-01T11:10:06-07:00	INFO	storagenode-updater/loop.go:18	Downloading versions.	{"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2024-06-01T11:10:10-07:00	INFO	storagenode-updater/update.go:22	Current binary version	{"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.104.5"}
2024-06-01T11:10:10-07:00	INFO	storagenode-updater/update.go:33	Version is up to date	{"Process": "storagenode-updater", "Service": "storagenode"}
2024-06-01T11:10:10-07:00	ERROR	storagenode-updater/loop.go:33	Error updating service.	{"Process": "storagenode-updater", "Service": "storagenode-updater", "error": "unable to determine binary version", "errorVerbose": "unable to determine binary version\n\tmain.binaryVersion:40\n\tmain.update:17\n\tmain.loopFunc:31\n\tstorj.io/common/sync2.(*Cycle).Run:99\n\tmain.cmdRun:138\n\tstorj.io/common/process.cleanup.func1.4:393\n\tstorj.io/common/process.cleanup.func1:411\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tmain.main:22\n\truntime.main:267"}
main.loopFunc
main.cmdRun
main.main
runtime.main
rc.d daemon
root@test-updater:~ # cat /usr/local/etc/rc.d/storagenode_updater
#!/bin/sh
# PROVIDE: storagenode_updater
# REQUIRE: LOGIN FILESYSTEMS netwait
# KEYWORD: SHUTDOWN
. /etc/rc.subr
name=storagenode_updater
rcvar=${name}_enable
load_rc_config $name
: "${storagenode_updater_storage_path:="/mnt/storagenode"}"
: "${storagenode_updater_enable:=yes}"
: "${storagenode_updater_executable:="/usr/local/bin/storagenode-updater"}"
: "${storagenode_updater_node_binary_location:="/usr/local/bin/storagenode"}"
: "${storagenode_updater_node_service_name:="storagenode"}"
: "${storagenode_updater_config_dir:="${storagenode_updater_storage_path}/config"}"
: "${storagenode_updater_identity_dir:="${storagenode_updater_storage_path}/identity/storagenode"}"
pidfile="/var/run/${name}.pid"
pidfile_child="/var/run/${name}_child.pid"
command="/usr/sbin/daemon"
command_args="-f -H \
  -o \"/var/log/${name}.log\" \
  -P \"${pidfile}\" \
  -p \"${pidfile_child}\" \
  -u root \
  \"${storagenode_updater_executable}\" run \
    --config-dir \"${storagenode_updater_config_dir}\" \
    --identity-dir \"${storagenode_updater_identity_dir}\" \
    --binary-location \"${storagenode_updater_node_binary_location}\" \
    --service-name \"${storagenode_updater_node_service_name}\" \
    --restart-method service"
run_rc_command "$1"
etc/rc.conf
root@test-updater:~ # cat /etc/rc.conf
cron_flags="$cron_flags -J 15"
# Disable Sendmail by default
sendmail_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
# Run secure syslog
syslogd_flags="-c -ss"
# Enable IPv6
ipv6_activate_all_interfaces="YES"
ifconfig_epair0b="SYNCDHCP"
netwait_ip="1.1.1.1"
storagenode_identity_dir="/mnt/storagenode/identity/storagenode"
storagenode_config_dir="/mnt/storagenode/config"
storagenode_storage_path="/mnt/storagenode"
storagenode_updater_config_dir="/mnt/storagenode/config"
storagenode_updater_identity_dir="/mnt/storagenode/identity/storagenode"
storagenode_enable="YES"
storagenode_updater_enable="YES"
newsyslog_enable="YES"
netwait_enable="YES"
file info
root@test-updater:~ # file /usr/local/bin/storagenode
/usr/local/bin/storagenode: ELF 64-bit LSB executable, x86-64, version 1 (FreeBSD), statically linked, for FreeBSD 12.3, FreeBSD-style, Go BuildID=xDRDdBUz-ti8IopWt5ao/5rWb1BXF4cehNI_Me4Zh/VO3gJB0EUrUtUqkasl2K/UJLOwf_nDvlmL8RkDepC, with debug_info, not stripped
root@test-updater:~ # /usr/local/bin/storagenode version
2024-06-01T11:21:48-07:00	INFO	Anonymized tracing enabled	{"Process": "storagenode"}
Release build
Version: v1.104.5
Build timestamp: 14 May 24 13:20 PDT
Git commit: f3a059560507912f8c471e838826a77b56b459a7
root@test-updater:~ # file /usr/local/bin/storagenode-updater
/usr/local/bin/storagenode-updater: ELF 64-bit LSB executable, x86-64, version 1 (FreeBSD), statically linked, for FreeBSD 12.3, FreeBSD-style, Go BuildID=IlKqOlZj4fKpm3U7ZYrN/q7GXJ5FzeKW05Vg1Rdwd/qjwtc0Dqy2eg1IT670xB/UbCXjc1hcRWvbUhTgFnY, with debug_info, not stripped
root@test-updater:~ # /usr/local/bin/storagenode-updater version
2024-06-01T11:22:08-07:00	INFO	process/tracing.go:73	Anonymized tracing enabled	{"Process": "storagenode-updater"}
Development build
Build timestamp: 29 May 24 03:58 PDT
Git commit: 930e83b946a665b2d1b38978d957706b9a5f21d1
Thanks for the testing. I checked the code, and it happens when you use a development build.
Can you please check if the output of the storagenode version contains a version?
It’s missing if you build storagenode from main (or other non-released commit).
I think it’s intentional to keep custom builds instead of overwriting them with the latest version.
Storagenode is release, see the version output in my post above
