After 2 days planned maintenance downtime my node shows up again on 2022-11-08T23:00:00Z with ~89% onlinescore orange colored on dashboard.
A few days later my node updated to v1.67 (watchtower) the onlinescore hasnt changed so far
but the onlinescore now shows up red colored related to Release Preperation v1.67 i guess.
Today my node was suspended on the first satellite
"Your Storage Node on the europe-west-1 Satellite was suspended because it produced errors too often during audits.
You were suspended on 2022-11-25 at 16:15 UTC."
Weird because i cannot find any issues, the onlinescore seems to be frozen since my node went online again on 2022-11-09… Node runs flawless the last 3 Years.
Auditscore:
for sat in `wget -qO - localhost:14002/api/sno | jq .satellites[].id -r`; do wget -qO - localhost:14002/api/sno/satellite/$sat | jq .id,.audits; done
"12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo"
"auditScore": 1,
"suspensionScore": 0.9998400391155746,
"onlineScore": 0.8907883188140794,
"satelliteName": "us2.storj.io:7777"
"1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"
"auditScore": 1,
"suspensionScore": 1,
"onlineScore": 0.8938881790326841,
"satelliteName": "saltlake.tardigrade.io:7777"
"121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"
"auditScore": 1,
"onlineScore": 0.8956448345397156,
"satelliteName": "ap1.storj.io:7777"
"12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"
"auditScore": 1,
"onlineScore": 0.8964160471553075,
"satelliteName": "us1.storj.io:7777"
"12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"
"auditScore": 1,
"onlineScore": 0.8959536633828439,
"satelliteName": "eu1.storj.io:7777"
"12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB"
"auditScore": 1,
"onlineScore": 0.8927838837750933,
"satelliteName": "europe-north-1.tardigrade.io:7777"
Logs:
docker logs storagenode 2>&1 | grep -E "GET_AUDIT|GET_REPAIR" | grep failed
2022-11-16T17:41:58.354Z ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "FDID6DIMRB7IGMCS2Y2NSL7VDAEZ6ORFZY4S6CM3VPQVJVQOFKXA", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->5.161.130.154:45912: write: connection reset by peer", "errorVerbose": "write tcp 172.17.0.3:28967->5.161.130.154:45912: write: connection reset by peer\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:628\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-11-16T17:43:30.276Z ERROR piecestore download failed {"Process": "storagenode", "Piece ID": "ZHR2ZNDL5RZJEA6UE6AZQZNSGUCSDZZD4VFLTMNP24S4YT5XGOUA", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.3:28967->5.161.130.152:45544: write: connection reset by peer", "errorVerbose": "write tcp 172.17.0.3:28967->5.161.130.152:45544: write: connection reset by peer\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:628\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
docker logs storagenode 2>&1| grep FATAL
2022-11-14T20:11:18.368Z INFO piecestore upload started {"Process": "storagenode", "Piece ID": "KFVMO3GSFYTFVBE6BJIEUHVBMFATALH6BAMEVYSWXSHSRDQZVCNQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Available Space": 2491652895488}
2022-11-14T20:11:21.895Z INFO piecestore uploaded {"Process": "storagenode", "Piece ID": "KFVMO3GSFYTFVBE6BJIEUHVBMFATALH6BAMEVYSWXSHSRDQZVCNQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT", "Size": 2174464}
2022-11-21T18:34:36.270Z INFO piecedeleter delete piece sent to trash {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Piece ID": "UCEOGMD4MXN7HCKBR3POST2QJFATALJFKQ6JH3EACGVBN24PCNYQ"}
Auditlogs from europe-west limited on 2022-11-25T23:00:00Z
docker logs --since 2022-11-26T00:00:00Z storagenode 2>&1| grep GET_AUDIT | grep 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs
2022-11-26T00:00:48.665Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "4DGIH26FM3HB3RVW4RZW26HJMAMCIKY6BT22EWDWXPPNS6GYRXBA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T00:00:48.712Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "4DGIH26FM3HB3RVW4RZW26HJMAMCIKY6BT22EWDWXPPNS6GYRXBA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T00:01:19.951Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "MN2DZVDR4Q44YCYFTF7RYFZYMVEX25DTDWUKLRMJKZSXSAVT4ECQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:01:05.069Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "MN2DZVDR4Q44YCYFTF7RYFZYMVEX25DTDWUKLRMJKZSXSAVT4ECQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:11:59.770Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "TJEGDA7S5RXQSWD2LT5ATX6MHYWB6XDYPVTGCMCFKKT2SNWXW5CA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:11:59.838Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "TJEGDA7S5RXQSWD2LT5ATX6MHYWB6XDYPVTGCMCFKKT2SNWXW5CA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:26:40.627Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "L37CAGPUTWTQHO4WSXDWAUEKLKSMZ63FP3URNTGUDLOIN4WW336A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:26:40.678Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "L37CAGPUTWTQHO4WSXDWAUEKLKSMZ63FP3URNTGUDLOIN4WW336A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:27:59.368Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "JAMSZDILLAAHNSYNTLJXJZ3BVWPUAABBA7TFXU6QQV4QMQE2JBXQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:27:59.422Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "JAMSZDILLAAHNSYNTLJXJZ3BVWPUAABBA7TFXU6QQV4QMQE2JBXQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:33:54.255Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "G66OA4ZBLAG244SYWE36AUM5V6HTODEJRODTKOCFMMNY3YPJ245A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:33:54.309Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "G66OA4ZBLAG244SYWE36AUM5V6HTODEJRODTKOCFMMNY3YPJ245A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:36:44.762Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "5DYAUI3PL7AFE6WP63M4CPAFAZT7COU4O675IF6LTRM75JL6BLMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T08:36:44.816Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "5DYAUI3PL7AFE6WP63M4CPAFAZT7COU4O675IF6LTRM75JL6BLMQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:19:59.520Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "6Y5DNGECE67SAMNVNSKP7DNJNRI7TEYISSWDS44WGXSOG4IV7WXQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:19:59.572Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "6Y5DNGECE67SAMNVNSKP7DNJNRI7TEYISSWDS44WGXSOG4IV7WXQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:22:24.154Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "DMLCLVO4QWLKHHOAAYJ6TIO6RDMA6FBXMCIBRYG2BJTP2TKRZSIQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:22:24.216Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "DMLCLVO4QWLKHHOAAYJ6TIO6RDMA6FBXMCIBRYG2BJTP2TKRZSIQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:56:45.485Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "CS3ZZRIXJ2RZBVQ6N2HM6NERI5RWSPY66AC7VCOJFUOCZQIUNCCQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T09:56:45.553Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "CS3ZZRIXJ2RZBVQ6N2HM6NERI5RWSPY66AC7VCOJFUOCZQIUNCCQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:04:03.697Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "AMHLKOZGVN3DEDX7OQWF2JBRIPSPFVKF3VETJ7PUHWMQPNVE5PVQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:04:03.769Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "AMHLKOZGVN3DEDX7OQWF2JBRIPSPFVKF3VETJ7PUHWMQPNVE5PVQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:07:36.711Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "E3ADJZYP3WJSAUXOG2CE4RX3T2HMUWH4KEBWOUQ4TPJX5GSTG2PQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:07:36.757Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "E3ADJZYP3WJSAUXOG2CE4RX3T2HMUWH4KEBWOUQ4TPJX5GSTG2PQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:12:00.340Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "SZ55BX6F4TZX3AKQBIROUELT4YUBJJWUVDITYHWBC6MOKUDDLNGQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:12:00.392Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "SZ55BX6F4TZX3AKQBIROUELT4YUBJJWUVDITYHWBC6MOKUDDLNGQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:15:32.911Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "PTC723PI3DQMCZLEPJLZO2IVYM2BDZFOFWVI62RI4VVREYRNTS7Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:15:32.966Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "PTC723PI3DQMCZLEPJLZO2IVYM2BDZFOFWVI62RI4VVREYRNTS7Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:32:26.313Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "WDIJZDGOCJGXP3CR55F26J4DG4GLH6XWTIK65YXAPCE4Z6AHDKRQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:32:26.365Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "WDIJZDGOCJGXP3CR55F26J4DG4GLH6XWTIK65YXAPCE4Z6AHDKRQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:35:03.608Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "VSDLWR3FKUJVOHCJ2X5QAQXF4GFNRDK3UQL2JYUY4WU3AKFONW2Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:35:03.648Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "VSDLWR3FKUJVOHCJ2X5QAQXF4GFNRDK3UQL2JYUY4WU3AKFONW2Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:37:56.446Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "NA4SQG7HZB5KKMFJXMWU5ETZO5VDIKCGPBVZ4CNHQ4JB6IJDGWEQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:37:56.511Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "NA4SQG7HZB5KKMFJXMWU5ETZO5VDIKCGPBVZ4CNHQ4JB6IJDGWEQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:42:50.543Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "ITVQ4NZS47YBWRZLAL2QHQUJCGB4SZST5XQFCTBPYVZJLTHH3IHA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T10:42:50.595Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "ITVQ4NZS47YBWRZLAL2QHQUJCGB4SZST5XQFCTBPYVZJLTHH3IHA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:11:15.569Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "FX2ZRJNWBPFIBR7WSWNFUJX7Q6UBYNPEGPI5XZGHMUVQYE7KKYTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:11:15.634Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "FX2ZRJNWBPFIBR7WSWNFUJX7Q6UBYNPEGPI5XZGHMUVQYE7KKYTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:21:48.676Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "54A3IJGO6ACTVEYHR457VEDWOJZR2H3C6DFBBRDOVSPGBVSDAEJQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:21:48.780Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "54A3IJGO6ACTVEYHR457VEDWOJZR2H3C6DFBBRDOVSPGBVSDAEJQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:26:53.825Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "7B2UHQY3FDV25N66JG7RDLIVSYPHI2QTTLCFFS3PPBUHTYBEGWDA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:26:53.885Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "7B2UHQY3FDV25N66JG7RDLIVSYPHI2QTTLCFFS3PPBUHTYBEGWDA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:31:39.321Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "NVUZKXT3WRDXLSEB4ABZ5GOKA47GZOEK6KGNB2CCQVJBMYDZXAQQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:31:39.373Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "NVUZKXT3WRDXLSEB4ABZ5GOKA47GZOEK6KGNB2CCQVJBMYDZXAQQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:38:29.031Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "DZDN6DGR42BKM352P22AA7ZH2KI7B5OYN6BIL6DWU6FOF6ETNMGA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:38:29.088Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "DZDN6DGR42BKM352P22AA7ZH2KI7B5OYN6BIL6DWU6FOF6ETNMGA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:43:53.746Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "TR4AT2WFKPDCRSNH7HA5C5LKAH65MKW3A3OGFESGEIDOAX4LTMTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T11:43:53.800Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "TR4AT2WFKPDCRSNH7HA5C5LKAH65MKW3A3OGFESGEIDOAX4LTMTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:06:54.113Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "V2AJH2HVEIKS7R7NECLR325OBCACEGDFEK3QSPHERPQJ4NCTIF6Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:06:54.170Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "V2AJH2HVEIKS7R7NECLR325OBCACEGDFEK3QSPHERPQJ4NCTIF6Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:09:11.226Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "VKWYH727VNRSYWVPDBIFOSS6IA3UXNRGEQIDPLGYTA2HKUZEH6RA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:09:11.282Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "VKWYH727VNRSYWVPDBIFOSS6IA3UXNRGEQIDPLGYTA2HKUZEH6RA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:21:49.027Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "CE3HCKXJYRFCVYZ6NRKSABTISVBUVEOF2WENXDY6URCWHP5VUBGA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:21:49.084Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "CE3HCKXJYRFCVYZ6NRKSABTISVBUVEOF2WENXDY6URCWHP5VUBGA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:22:41.609Z INFO piecestore download started {"Process": "storagenode", "Piece ID": "TQWZXRFYBKXYPEM7IQCKZEEZVLO7GZDCTA3NFP5QX655UTPJLGAQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
2022-11-26T12:22:41.678Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "TQWZXRFYBKXYPEM7IQCKZEEZVLO7GZDCTA3NFP5QX655UTPJLGAQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_AUDIT"}
Now, what am i missing here?
If the node was able to get audits, then the node was surely online.
Any clues why the onlinescore is still frozen?
Thank you a lot.
