FTP Issues Downloading and Uploading
So now I am having issues with ftp once again this time with uploading, which is sketchy and uploads in strange small bursts…and downloading thru ftp failing with messages like this
I can download the thing fine through browser
When you use a native integration, it opens for uploads 130 connections in parallel for the each segment of the file (64MiB or less), when the first 80 are uploaded all remained are canceled.
If you want to have a more stable uploads, you need to increase a parallelism (how many segments the libuplink can upload in parallel), in FileZilla it’s located in the menu EditSettingsTransfersLimit for concurrent uploads.
You may use rclone instead:
rclone copy --multi-thread-streams=8 --multi-thread-cutoff=64M -P "c:\Users\shiny\Downloads\Twisted Metal (USA).chd" storj:emulation/PS1
or with uplink:
uplink cp --parallelism=8 "c:\Users\shiny\Downloads\Twisted Metal (USA).chd" sj://emulation/PS1/
The number of threads (or concurrent uploads/downloads) will affect how much connections it will open and how much memory and CPU will be used. If your router is not capable to handle so much connections, this may reduce the speed or increase the number of retries.
Errors during download are related to unstable connection. With a native integration it opens 35 connections for the each segment and downloads in parallel. When the first 29 are downloaded all other are canceled.
If you upload and download in the same time, it may overload your router if it’s not capable to handle so much parallel connections. So you may reduce the number of parallel transfers in the menu EditSettingsTransfersMaximum simultaneous connections
If you upstream or downstream bandwidth of your internet connection are small (less than 25Mbit for upstream and less than 100Mbit for downstream), perhaps it’s better to use an S3 integration instead, it’s supported by FileZilla PRO, Cyberduck, rclone and many others.
See also
Update ya s3 is way more reliable for me, and it means I get to use filezilla for all my storage uses
