FTP problems and stuff
So using filezilla I can not get any of the files I uploaded from the website…how do I fix this?
Whenever I use FTP I get none of the same files as the website what’s up with that? how do i fix it?
You need to create an access grant for FileZilla using exactly the same encryption phrase, used during upload via web UI.
The encryption phrase is not tied with the bucket, it’s used to encrypt and decrypt objects in any bucket.
With a different encryption phrase your objects cannot be decrypted, and your buckets will look like empty.
