Hello,
If I share access to a file with someone using uplink, is it possible for that user to deduce the full path of the object from the API key, or do I also need to share with them the path? Or is there anyway for the shared user to access the file without the full path?
E.g. if I share sj://mybucket/myfile with a user and they import that access file, they can see “myfile” when they run “./uplink access list”, but to download the file they seem to have know the full path “sj://mybucket/myfile”. Is there anyway they can download this file without the full path, or work out the path from the API key?
Thanks
