Good Hardware solutions for nodes?
I made it only for 20Hdds to make bigger spaces, also i got used case for 40$ only, and make cages for my self from cardboard. It is very cheap solution. at home is is 25 Celsius, and Hdds are 29-33 Celsius
It is only 4 cardboard layers on top glued, and 4 at bottom, with slots for hdds, at most bottom is foam layer, to suppress vibration from case.
This is equally genius and horrifying.
What MLB is this?
(the most annoying feature of the MLBs is when they decide to position memory perpendicular to airflow. Why do those exist I have no idea..)
MLB? dont know this abriviation
It is NAS motherboard, link is on first post.
Despite it is china product, it has 2025 bios, with reach features. like obfuscation of pcie, hot swap 10x sata
2x NVME support. 6 RAM ports with up to 32GB ram each 4 channels. also i like small size, no overhead.
Ah, missed that, my bad.
I don’t see anything wrong with Chinese motherboards – today most of the heavy lifting is done by the chipset vendors; creating a PCB by often reference design, producing it, and ordering assembly is accessible to anyone. You can design and get your own motherboard manufactured if you wanted to :slight_smile: As long as signal integrity passes (Which is validated at the design stage by various tools) and the parts are working (validated at the production stage) all you are risking is getting lower binned parts – and the worst that can happen you’ll get some instability under some conditions…
P.S. MLB == Main Logic Board. aka mainboard, aka motherboard, seems to be more widespread term in the US.
:slight_smile:
Was it HP or IBM that used to call a FAN an AMD (Air Movement Device)
