best tip i can give you is to learn linux admin, i was a windowze boy but for production servers nothing can compete with linux
I know you run multiple nodes on multiple servers and best you can do is give a try to truenas scale o proxmox, SMART alert capaibilties builtin with email alerts, hardware related admin and easy to manage multiple rigs into a sincle cluster view
Yes, linux will support old hardware a long time. I would recommend Proxmox for virtualization. Or just use bare matel machine and use docker there directly. Then you don’t have any losses through virtualisation.
I personally would use proxmox if you want to use it for other services too and Linux bare if it is only for storj
this motherboard you mentioned, is not even support NVME and i thing boot from nvme also.
on chanese one there is 10 sata ports and if add HBA with 16 ports it is more than enough.
2.5Gbit ports are also very good. PCIE supports all kind of obfuscations according to description.
even newes affortable CPU and motherboard dont have so many pcie lines, i have one i3-10100 with B560 dont work even near that good like e5-2680 platforms. When it usual work it is OK, but as there is big deletes, it turns to be not very accessible for some time. But CPUs not overloaded at this time, my theory it is because small amount of pcie.
An i3-10100 is overkill for Storj, and the number of PCIe lanes doesn’t matter unless you’re connecting multiple PCIe devices. Also, don’t underestimate the power usage of those old platforms. If you tune that i3 correctly, I’d expect you to achieve around 25 to 35 watts of idle power consumption. As for the problems you’re experiencing, I’m just going to blame it on you using Windows instead of Linux.
I have other i7-6700 and one hdd was all the time slow, it was turned to pciex1 with adapter.
turned out, when i I turned off anymore not necessary NVME on other slot, this hdd started to work OK, so lack of pcie lanes is real on desktop cpus.
I have several Chinese X99 motherboards running E5 Xeons. Found them to be great. Cheap, powerful, reliable, but yes old tech.
If your building storage machine, start with an old enterprise disk shelf/array and suitable hba catd, rather than buying motherboards with 10x sata. SATA designed for desktop use.
I like this idea: ensure the PC supports enough RAM to run all the nodes you may want… then slap in a cheap HBA with external ports. CPU is almost free these days… but I guess you’d also want to make sure it fits all the flash you want too. Doesn’t need to be fancy
this is how it looks now, with new motherboard
I combined 2 servers with 8 hdd to one bigger server.
it has better cooling solution, Xeon cpu, 96GB of RAM
650W Seasonic Power.
i purchased a case like that 2 years ago but unfortunelly didnt work for me. I like the hdd cover for better air tunneling. The case i’ve had was for 24 hdd in two rows like yours, my version was very hot for hdd because they was more tight than yours
