Hello everyone, I am new to the community, I have a question, is there the possibility of creating a node with googleDrive? Can I use my space on googleDrive as a node storage? Thank you very much.
bre
March 20, 2022, 6:56am
#2
Welcome to the forum @andres84 !
This thread will explain why its not recommended to create a node with Google Drive
Hey node, welcome to the forum!
Using google drive for storj is a really bad idea. This will add a lot of additional latency and will really mess with the workings of your node.
The idea of storj is to store data decentralized. If nodes are going to store it on another cloud somewhere, they would also be reintroducing a single point of failure. In short, you should really not be using google drive at all.
However, the debugging steps are the same no matter what you use. Have a look at your do…
