After latest update today (v0.27.1) i found in my docker logs:
Those log entries are nearby every minute!!!
2019-12-11T20:50:00.807Z INFO piecestore uploaded {"Piece ID": "63IFV5URN6JXAJBJQMIX62KIJ3NJASJXVRRZMSBO7PTY7XTTOEJA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT"}
2019-12-11T20:50:01.943Z INFO piecestore upload started {"Piece ID": "B46GKFJCLFXWHP3IQ2UGSMWF2PS263AQGN4NPCB6NS7Z4F5BKEKQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT"}
2019-12-11T20:50:02.479Z INFO piecestore upload started {"Piece ID": "BDE6QSMJPQBOV7M5QQCO6SYZQI5LOQMTFTJXVF7V5XZ4KJAO4UNQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "PUT"}
2019-12-11T20:50:02.561Z INFO piecestore upload started {"Piece ID": "H7HCW4BI3JZDOFTSYN67OOER5M4NBREZN5YFHTSKRAH7AO7YV3SA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT"}
2019-12-11T20:50:02.680Z INFO Got a signal from the OS: "terminated"
2019-12-11T20:50:02.737Z ERROR piecestore:cacheUpdate error getting current space used calculation: {"error": "context canceled"}
2019-12-11T20:50:02.740Z ERROR piecestore:cacheUpdate error persisting cache totals to the database: {"error": "piece space used error: context canceled", "errorVerbose": "piece space used error: context canceled\n\tstorj.io/storj/storagenode/storagenodedb.(*pieceSpaceUsedDB).UpdateTotal:115\n\tstorj.io/storj/storagenode/pieces.(*CacheService).PersistCacheTotals:82\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run.func1:68\n\tstorj.io/storj/private/sync2.(*Cycle).Run:87\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:63\n\tstorj.io/storj/storagenode.(*Peer).Run.func6:445\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2019-12-11T20:50:02.839Z INFO piecestore uploaded {"Piece ID": "6SDEYRW77QK6QP7ELZWQIKLUASOVPB7TCGVNQW5JPVUONVQRD3VA", "Satellite ID": "118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW", "Action": "PUT"}
2019-12-11T20:50:02.842Z INFO piecestore upload failed {"Piece ID": "H7HCW4BI3JZDOFTSYN67OOER5M4NBREZN5YFHTSKRAH7AO7YV3SA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "PUT", "error": "piecestore protocol: context canceled", "errorVerbose": "piecestore protocol: context canceled\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).doUpload:344\n\tstorj.io/storj/storagenode/piecestore.(*drpcEndpoint).Upload:223\n\tstorj.io/storj/pkg/pb.DRPCPiecestoreDescription.Method.func1:985\n\tstorj.io/drpc/drpcserver.(*Server).doHandle:175\n\tstorj.io/drpc/drpcserver.(*Server).HandleRPC:153\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:114\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:147\n\tstorj.io/drpc/drpcctx.(*Tracker).track:51"}
So the node is restarting all the time. There is noone who stops the container. So it seems Storj is shutting down itself, but restarted by the restart-policy.
docker-compose.yml:
version: "3.7"
services:
storagenode_1:
container_name: storagenode_1
image: storjlabs/storagenode:beta
restart: unless-stopped
stop_grace_period: 300s
ports:
- "28967:28967"
- "14002:14002"
volumes:
- type: bind
source: /root/.local/share/storj/identity/storagenode_1
target: /app/identity
- type: bind
source: /mnt/storj_data_1
target: /app/config
environment:
WALLET: "XXXXXX"
EMAIL: "XXXXX"
ADDRESS: "XXXXX"
BANDWIDTH: "30TB"
STORAGE: "8.5TB"
logging:
driver: "json-file"
options:
max-size: "50m"
max-file: "3"
HDD is a dedicated one only for storj.
Runnin as root.
What should i do?
