Graceful exit does nothing
I ran the “graceful exit” command to exit all satellites, and left it for about 3 weeks. I see that nothing has happened:
2025-01-04T23:13:27Z    INFO    Configuration loaded    {"Process": "storagenode", "Location": "/app/config/config.yaml"}
2025-01-04T23:13:27Z    INFO    Anonymized tracing enabled      {"Process": "storagenode"}
2025-01-04T23:13:27Z    INFO    Identity loaded.        {"Process": "storagenode", "Node ID": "1zvpLaX32oteu9TPHUUucPWgcGd3fAyUcXo7U1sdaTNNGKAW5S"}
Domain Name                  Node ID                                              Percent Complete  Successful  Completion Receipt
saltlake.tardigrade.io:7777  1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE   0.00%             N           N/A
ap1.storj.io:7777            121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6  0.00%             N           N/A
us1.storj.io:7777            12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S  0.00%             N           N/A
eu1.storj.io:7777            12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs  0.00%             N           N/A
However I did see a bunch of DNS errors at various points. I don’t have DNS issues on my box. Should I just pull the plug on the docker container?
Graceful exit doesn’t show progress… it will look like nothing is happening for 30 days… then it will magically complete.
