Hi, I have been waiting the graceful exit for the 5Tb output for almost a month but there are two satellites (us2.storj.io:7777 and europe-north-1.tardigrade.io:7777)that are still at 0.00%. I am going to turn off the server in a week and I need to finish as soon as possible. Somebody could help me?
This is the important part:
Graceful Exit only works if the satellites are active, since they are distributing your data to other node operators. But they are not active therefore your GE is not progressing.
If you have already performed GE on other satellites and only these 2 are remaining then you can delete your node data for these 2 satellites.
Make sure you keep the receipt of your GE for other satellites.
I would suggest to keep your identity for this node on case if you change your mind later and would like to opt-in for zkSync to receive a final payout independently of the Minimum Payout Threshold on Ethereum.
Understood, thank you very much for the information. Cryptocurrencies are no longer profitable.
Regards!!
