On one of my Nodes i startet graceful exit. On the following satelites i have 100% successful exit:
us2.storj.io:7777
saltlake.tardigrade.io:7777
ap1.storj.io:7777
eu1.storj.io:7777
europe-north-1.tardigrade.io:7777
but on this satelite:
it stucks at 30.77%
In my log i see this:
2022-11-05T14:35:57.271Z INFO piecestore downloaded {"Process": "storagenode", "Piece ID": "XNIIYI6HUHZHHDFKBZZ46A5PNO5NDQHZF3NJGBJJHMARARPYS6XQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR"}
2022-11-05T14:39:28.071Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2022-11-05T14:39:28.565Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.65.1"}
2022-11-05T14:39:28.565Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2022-11-05T14:39:28.598Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.65.1"}
2022-11-05T14:39:28.598Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2022-11-05T14:40:13.966Z ERROR gracefulexit:chore worker failed {"Process": "storagenode", "error": "graceful exit processing interrupted (node should reconnect and continue)", "errorVerbose": "graceful exit processing interrupted (node should reconnect and continue)\n\tstorj.io/storj/storagenode/gracefulexit.(*Worker).Run:90\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing.func1:82\n\tstorj.io/common/sync2.(*Limiter).Go.func1:49"}
2022-11-05T14:42:03.281Z ERROR gracefulexit:chore worker failed {"Process": "storagenode", "error": "graceful exit processing interrupted (node should reconnect and continue)", "errorVerbose": "graceful exit processing interrupted (node should reconnect and continue)\n\tstorj.io/storj/storagenode/gracefulexit.(*Worker).Run:90\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing.func1:82\n\tstorj.io/common/sync2.(*Limiter).Go.func1:49"}
2022-11-05T14:42:48.276Z ERROR gracefulexit:chore worker failed {"Process": "storagenode", "error": "graceful exit processing interrupted (node should reconnect and continue)", "errorVerbose": "graceful exit processing interrupted (node should reconnect and continue)\n\tstorj.io/storj/storagenode/gracefulexit.(*Worker).Run:90\n\tstorj.io/storj/storagenode/gracefulexit.(*Chore).AddMissing.func1:82\n\tstorj.io/common/sync2.(*Limiter).Go.func1:49"}
