Hi guys, just sharing my first GE on my oldest node:
It took 9 days to gracefully exit 3TB data on 4 satellites.
I believe the other satellites were not successful because they were less than 6 months old.
common man
you could earn like 5 dollars a month
all you have to do is 20 things and stuff
lambo soon
his other nodes might still be running.
They are
and just got expanded adding 10TB more ![]()
A RPI 3B+ just wasn’t efficient enough. In the meanwhile I got 3 HP Microservers and 2 Synologys ![]()
Got a bunch of old gen8 (celerons and xeons) and they are performing pretty well.
What are the specs of yours?
Pretty basic ones.
I have 1 of each:
N36L, N40L and N54L.
The most spec´ed one has 8GB memory and that is it ![]()
More than enough for storj nodes. ![]()
Was there a specific reason you chose to GE instead of migrating the identity + data to the new server? This would have let you skip both the vetting period, as well as skip months of high repair escrow.
There was. I had 2 nodes under the same IP and both full. Didn’t want to add a third.
So GEd one of them, slowest one, and expanded the other one.
So I just keep one, but bigger and more efficient.
