Graceful exit - Q
Hi all,
I’m wondering if someone knows how to find out what date you started graceful exit ?
When i query exit-status , it just shows 0% ? does it not gradually increase ?
Thanks in advance
It doesn’t increase, you will get either 100% after 30 days online or disqualified (if you fail to keep it online for the last 30 days since the graceful-exit is invoked).
See Graceful Exit Guide (new procedure as of 2023-10-?)
thanks @Alexey - appriciate all your posts on the community
How could I find out when I started it ?
Cheers
It should be in your logs, search for grace.
