I started the graceful exit and after a week and the check command still shows 0.0% on all satellites
Is there a way to speed this up or get more data bout what’s going on?
Thanks!
Thanks!
I’m still lost
Storj is sending data out, but there’s nothing in the logs or the status check to see if it’s working or if there’s a problem…
The check command will show 0% until your graceful exit is done. That is a relic from the old graceful exit, where nodes transferred pieces directly between each other. Now, with the new time-based graceful exit, you just need to make sure your node is online and serving pieces as requested for some period of time, and then you are done. The only relevant measures to watch in the meantime are your reputation scores.
