I am exiting a few nodes and regarding europe-north-1.tardigrade.io:7777 satellite they are all at 0% completion. Some other satellites already completed but this one is at 0%. Exit operations started a couple of weeks ago, so I don’t understand what is wrong here?
Here are my settings, I tried to do some tuning:
You should receive a full held amount from these satellites with the nearest payout, if your node would clear a Minimum Payout Threshold, otherwise it would be added to the undistributed amount and will wait until the undistributed amount would clear the threshold.
Thank you @Alexey , I guess it explain my situation and that I should have payed more attention to Storj Labs emails!
I have two remaining questions however:
was there a delete process of these satellites data?
everything ok with us1.storj.io:7777? Two of my exiting nodes are now stuck around 50% on this satellite.
Yes, it was deleted, as announced. It doesn’t matter anyway, If your node still has some data from these satellites, because you called a GE. You likely would delete this node anyway, so no special actions are needed for the exiting node.
No problems have been detected. But I would like to suggest to check your logs, does your node have issues with pieces transfers? Search for graceful or transfer and ERROR or failed.
