Hi guys,
My node got disqualified because of what I think are some problems with the motherboard I use, after 12-13 days of uptime it just loses the drive with the storagenode data on it and I have to power the pc down and disconnect and reconnect the drive. But since I am not always home the audit fell rapidly.
The problem I am facing now is I tried doing a gracefull exit but after a few minutes when checking with
"C:\Program Files\Storj\Storage Node\storagenode.exe" exit-status
it just tells me
"No graceful exit in progress."
before that I can see the sattelites with 0% completion.
The command I am running is
"C:\Program Files\Storj\Storage Node\storagenode.exe" exit-satellite --identity-dir "C:\Users\Administrator\AppData\Roaming\Storj\Identity\storagenode" --config-dir "C:\Program Files\Storj\Storage Node" --log.output stderr
and put all the sattelites when asked which one to exit from.
satellite.stefan-benten.de:7777 118UWpMCHzs6CvSgWd9BfFVjw5K9pZbJjkfZJexMtSkmKxvvAW 19.4 GB
saltlake.tardigrade.io:7777 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE 337.8 GB
asia-east-1.tardigrade.io:7777 121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 93.2 GB
us-central-1.tardigrade.io:7777 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S 99.2 GB
europe-west-1.tardigrade.io:7777 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs 549.4 GB
europe-north-1.tardigrade.io:7777 12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB 648.0 GB
Anyone has any ideas?
Thank you
