Hi,
What’s happening to a node after successfully gracefully exit completed?
My node is still running and earning.
thx
Hi,
thx
If your node is exited from all trusted satellites, they would not offer your node for the customers any longer and the node wouldn’t receive any new data. However, the node may be used for the repair traffic, if it would be still online.
But if you have a successful graceful exit receipts, you may keep them with the NodeID to provide them, if you would need to contact support.
I would also recommend to keep the node’s identity somewhere on case if the Undistributed amount including the returned held back amount would not be enough to clear a Minimum Payout Threshold in the next month and you would like to opt-in for zkSync Era to receive it there (the minimum payout threshold is much lower on zkSync Era).
So, after a full graceful exit from all satellites you may shutdown this node and remove its data.
