Is there any hint about this display issue in Grafana dashboard?
Did you mean the name of the satellite to be written completely before showing the bars?
Yes but dont know the solution.
As I know, there is no solution right now but adjust the resolution of panel can fix it.
However, you can try using the previous version of Grafana maybe it’s work like before.
