Hey,
finally had my node spun up properly.
The GUI dashboard is showing the bandwidth usage correctly, but not the disk usage it’s showing on the cli dashboard - is that normal? Will it update? Should I be worried?
Hey,
I think it’ll update every hour or so. It’ll show up soon enough.
Great, thanks, so I thought
Just wanted to make sure as I was messing around with these now so was in the mode to get this done
