Hard faults in Memory
Hello.
Does someone know why 1 storage node from 17 getting so many hard faults in memory.
I made HDD check, during check it worked without faults, but after check ended started again.
any ideas how to investigate that?
Why would a hdd check help for faults? You just don’t have enough memory to keep all frequently accessed data in memory.
Thank you for information, I thud this is some errors in memory. SO no big deal, But i already have here 56GB of RAM
Hard fault is just an event where the operating system had to bring something from disk an application expected to already be in memory. This usually means excessive use of swap.
Ok thanks, I have page files on NVME
