Has anyone's storagenode auto-upgraded using watchtower to version 1.3.3?
Heya,
I have followed the steps mentioned in https://documentation.storj.io/setup/cli/software-updates
to start watchtower for auto-upgrade.
My storagenode is at version v1.1.1 and I received notification to upgrade the node to v1.3.3 around 18 hours ago.
I thought the node would be auto-upgraded but it did not, unsure if this is a bug?
Has anyone seen this happen in their environment?
Cheers!
The notification is a bug. The storage node should not update.
Oh I was going through other posts in the forum, I was just thinking if I need not do anything. Thank you.
Hi,
Watchtower took about 7 days to update my node. (the message Update your Node to Version v1.3.3 has been displayed 7 times in my dashboard notification).
Is this duration normal ?
Thanks in advance.
Hogion
Yes, it’s normal when using a rolling-update strategy.
The message is broadcasted to every node at the same time, but your node gets updated when it’s its turn.
OK !
Thanks for the explanation.
Hogion
