Hashstore rollout commencing!
There is one thing that I have just noticed today: On several nodes that have already completed migration, the switch only in 1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE.migrate_chore has reverted to true. This comes after migration had already been fully completed and all migration switched had been set to false to prevent further IO spent on this.
All other migration chore files have their switches set to false. From the date of the file it seems the changes has been made on the 15th of May.
Has the switch been set by Storj?
Or by your docker. Did you remove the container before changing these files?
But perhaps you are correct. I saw a message on May 15 for active migration on SLC 100% (it was gradual)
Yes. Each container was stopped and removed before setting the values to false.
I see modification date 14th of May on one node and 15th on multiple others. That would fit.
It’s possible that the storage node synchronized the state from the satellite, at least the date matches.
Ok, but the nodes are full migrated. Can we prevent it somehow that it keeps turning itself back on?
What is issue with having it enabled, if blobs are empty? Also you may try to change it and set as read-only.
also
$ storagenode setup --help | grep migr
      --storage2migration.suppress-central-migration             if true, whether to suppress central control of
migration initiation
This:
It shold not turn itself back on. I mean the problem is not that I can’t disable it again. The problem is that I would have to monitor the status for each satellite per node if Storj turns it on and off whenever they want to. If I turn it off it shold remain off.
You don’t. You can disable it entirely.
Right. But now there is no directories after successful migration, isn’t it?
Does this work in the Docker run command?
There are still those 2-letter subfolders. Mostly empty but some may contain broken pieces in it.
Yes, you need to put it after the image name.
I thought you cleaned up them? It also should remove empty directories after a successful migration:
Looks like this was never enabled? I found only mentions in tests.
as --storage2migration.suppress-central-migration=true or --storage2migration.suppress-central-migration="true" or --storage2migration.suppress-central-migration true?
No. I couldn’t be bothered to do that manually. And some are still there so it does not seem to happen automatically, I don’t know.
All three are valid.
I checked with CoPilot, the cleanup is happening during migration. So if all pieces are migrated, all their folders should be removed as well, including 2-letters directories. It even removes zero-sized objects and their directories. But didn’t remove non zero files and non empty directories.
Thanks. Will add that option then.
Well all I can say is that I can still see the subfolders… At some point I will have to remove them manuall if automatic removal is not working.
It is performed only during migration and never after. So if they are left, then they are likely not empty and you need to cleanup them manually, if the remained pieces cannot be migrated (you should see errors in your logs).
They look very empty to me:
ls storage/blobs/v4weeab67sbgvnbwd5z7tweqsqqun7qox2agpbxy44mqqaaaaaaa/2j | wc -l
0
Maybe automatic removal was not implemented when I migrated or it did not work. I have no idea. All I can say is that the folders are there and on most nodes completely empty.
The mentioned problem (slow ext4 with empty dirs) shouldn’t be a problem any more, as newest version cleans up the empty (but slow) directories.
Actually it makes more sense to turn in migration (at least a short period of time).
It’s merged in 1.149:
What is your version?
That’s interesting. Does it cleanup even though migration has been completed already? In that case the best way might be indeed to set the migration chores back to true.
What will happen if broken pieces are left in subfolders?
Subfolders with broken pieces will remain until you delete them. This chore can delete only zero-sized pieces and their subfolders.
Has Storj only enabled active-migration of SLC so far, or have a portion of nodes begun for other satellites too?
SLC is full done, AP is in progres (I think it’s at 50% now). US1 and EU1 are not yet touched.
