Held amount per node
Is there an interface that allows an SNO to enter a node address and see the held amount and payment schedule for it?
Thanks
Ilan
The storage node dashboard is showing it.
I am using the CLI version…
Thanks
Ilan
start using the dashboard :wink:
you can always use an ssh tunnel, no matter where the node is installed.
Thanks. I will try that.
:+1:
Setup the web-dashboard: https://documentation.storj.io/setup/cli/dashboard
And how to use it remotely: https://documentation.storj.io/resources/faq/how-to-remote-access-the-web-dashboard
