Hello, installation odroid
why didnt work, when i installed 1 odroid and worked… dont know where is problem
thanks
Ive
You mixed two repos - for Ubuntu and for Debian.
Now you need to clean source lists:
  • remove duplicates in /etc/apt/sources.list (it suggests lines 17, 19 and 23 have problems)
  • remove one of the distributions entries, I guess your current distro is Ubuntu 20.04, so you need to remove Debian sources.
im reinstalled it all…
cos i cant to find installation steps for odroid/ARM
There is no difference from installing a normal Ubuntu/Debian version.
Just follow the instructions for linux.
If you need help at any point, just ask.
I have the odroid HC4 and my installation queue is the following:
  • Docker
  • Portainer
  • CloudCMD
  • Watchtower
  • Storj Node
Super easy and I have a sexy webinterface to manage everything.
You could also install OMV and install the rest from there…
Someone else is having the same issue. I commented at that thread that there’s no focal docker-ce target for armhf. Considering installing the docker.io package from the base Ubuntu repos instead. That’s what I use for 6x Odroid HC2 units. Let me know if you need any further help getting Storj up and running on your Odroid.
