stefan-benten satelite is turned off forever. So no panic this is OK.
There is no minimum ammount of income data at all, this is not mining. So it can be no income data at all.
Yeah I know,but my first (3tb) was full within first month,and the other 2 nodes that I’ve installed are running that slow that just makes me thing somenthing is bad.
the 2º node I can understand why is running that slow,since is in the same network and devide than the 1º node,but the 3º node is in a completely separate location,with another IP block and all that…
at this rate seems like my nodes will take ages to become full stored.
by the way I just checked the node succes rates stats with this script and seems works perfect:
If you use a sudo when you run the docker run, then you need to use the same for the script, because It shows zeros instead of counts. This could be either because of no access or you redirected logs to the file or uses a different name for the storagenode.
For a different name you should specify it as an argument for the script. For a redirected logs you should specify a path to it as an argument.
As already mentioned before - there is no predictable pattern for customers’ usage. They use the network when they want, so any traffic is normal.
