Help logging download traffic
Hello!
I hace a bucket mounted via rclone remote to my system. What is the best way to log daily traffic to/from the rclone mount? I have tried activating the rclone log file but it doesn’t log traffic, just low level operations.
Has anybody implemented a solution for this?
--stats* See Global Flags
What are you trying to accomplish? Why do you want to monitor bandwidth?
Which cloud storage provider’s bucket is this ?
Hello @juangalt,
You may request to put logs to your bucket, however, for the native Storj integration it could be not possible.
The download traffic is related to your OS behavior - it downloads visible files to generate thumbnails.
I would like to suggest to disable the thumbnail generation, when you open a mounted bucket. You can use the --network-mode option in your rclone mount command if you use Windows. Or use the configuration options in your OS to prevent to generate them, like show a list, not tiles and do not generate any previews.
You may also increase the cache TTL with the option --vfs-cache-max-age, see rclone mount for details, then at least it would download files much less frequently.
Hello!
I want to log up/down traffic because this is an important componet of monthly cost. I have noticed that the downloaded traffic is 10x what I would expect, so I want to understand what is generating so much traffic.
I’m using a storj bucket
Thanks for the answer. I will request logs.
When you say it depends on os, I’m using linux+rclone, so I don’t think there is a thumbnail problem. I will play around with the cache too.
It’s still can be, if you use any GUI access.
