Hi Help,
My ARM64 node has run since mid July, it worked well for only first week with 40+ GB data storage. Starting from late July there was no any inputs/outputs, at that time log output sth. like vetting process incomplete, and I noticed a similar post in which the reporter was recommended to wait for one month to see whether the node would be recovered.
There was zero data in Aug and now it takes more than one month, there is still no data inputs/outputs, today I have just restarted the node with below command (proven working since original set-up)
Now there is error message like “server rpc error”, any idea?
Thanks
Larry
docker run -d --restart unless-stopped -p 4511:28967 \
-e WALLET="0x537eB99Acda********************" \
-e EMAIL="larry.****@******.com" \
-e ADDRESS="61.172.47.198:4511" \ (#I have fixed public IP address )
-e BANDWIDTH=20TB \
-e STORAGE=6TB \
--mount type=bind,source="/home/cc/.local/share/storj/identity/storagenode",destination=/app/identity \
--mount type=bind,source="/mnt/myhdd/storjv3",destination=/app/config \
--name storagenode storjlabs/storagenode:arm
root@cc_0394:/mnt/myhdd# uname -i
aarch64
root@cc_0394:/mnt/myhdd# docker logs --tail 50 storagenode
2019-09-02T08:15:47.592Z INFO Configuration loaded from: /app/config/config.yaml
2019-09-02T08:15:47.599Z INFO Operator email: larry.*****@*******.com
2019-09-02T08:15:47.600Z INFO operator wallet: 0x537eB99Acda************************
2019-09-02T08:15:53.809Z INFO version running on version v0.19.5
2019-09-02T08:15:53.897Z INFO db.migration Latest Version {"version": 18}
2019-09-02T08:15:53.910Z INFO bandwidth Performing bandwidth usage rollups
2019-09-02T08:15:53.913Z INFO Node 1fd6nap2vJHk7yUCeSULKYtdrsKSaJvd7s6LEDQjDLexUNRL5z started
2019-09-02T08:15:53.914Z INFO Public server started on [::]:28967
2019-09-02T08:15:53.915Z INFO Private server started on 127.0.0.1:7778
2019-09-02T08:15:53.947Z INFO piecestore:monitor Remaining Bandwidth {"bytes": 20000000000000}
2019-09-02T08:15:54.133Z INFO version running on version v0.19.5
2019-09-02T08:16:28.771Z ERROR server rpc error: code = PermissionDenied desc = untrusted peer 1QzDKGHDeyuRxbvZhcwHU3syxTYtU1jHy5duAKuPxja3XC8ttk
Storage Node Dashboard ( Node Version: v0.19.5 )
ID 1fd6nap2vJHk7yUCeSULKYtdrsKSaJvd7s6LEDQjDLexUNRL5z
Last Contact 0s ago
Uptime 3h17m37s
Available Used Egress Ingress
Bandwidth 20.0 TB 0 B 0 B 0 B (since Sep 1)
Disk 6.0 TB 32.7 GB
Bootstrap bootstrap.storj.io:8888
Internal 127.0.0.1:7778
External 61.172.47.198:4511
Neighborhood Size 150
