Storage node has been offline almost a week! No notification was sent, and the logs simply show this, I can confirm the node has internet acces, and port forwarding
2022-06-07T13:04:58.319327394Z 2022-06-07T13:04:58.318Z INFO piecestore downloaded {“Process”: “storagenode”, “Piece ID”: “MIRUQ4BV3A4BEQNOSBXG446BVXMCD4SFM6VHUVGV2ZSXBAGQDGXQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET_REPAIR”}
2022-06-07T13:06:01.257681052Z 2022-06-07T13:06:01.257Z INFO piecestore downloaded {“Process”: “storagenode”, “Piece ID”: “ZBHH46DETOCWE7UKIR4IX6BUUBX37NQCQE2TNKIU5HZZ22OEYIBQ”, “Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “Action”: “GET_REPAIR”}
2022-06-07T13:06:36.121855827Z 2022-06-07T13:06:36.121Z INFO Downloading versions. {“Process”: “storagenode-updater”, “Server Address”: “https://version.storj.io”}
2022-06-07T13:06:37.895980152Z 2022-06-07T13:06:37.894Z INFO bandwidth Performing bandwidth usage rollups {“Process”: “storagenode”}
2022-06-07T13:06:44.532094479Z 2022-06-07T13:06:44.531Z INFO orders.12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo sending {“Process”: “storagenode”, “count”: 6}
2022-06-07T13:06:44.532143359Z 2022-06-07T13:06:44.531Z INFO orders.12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs sending {“Process”: “storagenode”, “count”: 121}
2022-06-07T13:06:44.532147669Z 2022-06-07T13:06:44.531Z INFO orders.12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB sending {“Process”: “storagenode”, “count”: 210}
2022-06-07T13:06:44.532150199Z 2022-06-07T13:06:44.531Z INFO orders.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE sending {“Process”: “storagenode”, “count”: 609}
2022-06-07T13:06:44.532152468Z 2022-06-07T13:06:44.531Z INFO orders.121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6 sending {“Process”: “storagenode”, “count”: 97}
2022-06-07T13:06:44.532154619Z 2022-06-07T13:06:44.531Z INFO orders.12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S sending {“Process”: “storagenode”, “count”: 426}
2022-06-07T13:06:56.150069216Z 2022-06-07T13:06:56.137Z ERROR Error retrieving version info. {“Process”: “storagenode-updater”, “error”: “version checker client: Get “https://version.storj.io”: dial tcp: lookup version.storj.io on x.x.x.x:53: read udp x.x.x.x:45613->x.x.x.x:53: i/o timeout”, “errorVerbose”: “version checker client: Get “https://version.storj.io”: dial tcp: lookup version.storj.io on x.x.x.x:53: read udp x.x.x.x:45613->x.x.x.x: i/o timeout\n\tstorj.io/storj/private/version/checker.(*Client).All:68\n\tmain.loopFunc:21\n\tstorj.io/common/sync2.(*Cycle).Run:152\n\tmain.cmdRun:136\n\tstorj.io/private/process.cleanup.func1.4:372\n\tstorj.io/private/process.cleanup.func1:390\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:93\n\tmain.main:20\n\truntime.main:255”}
2022-06-07T13:06:57.896634119Z 2022-06-07T13:06:57.895Z ERROR contact:service ping satellite failed {“Process”: “storagenode”, “Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189”}
2022-06-07T13:06:57.896871721Z 2022-06-07T13:06:57.895Z ERROR contact:service ping satellite failed {“Process”: “storagenode”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189”}
2022-06-07T13:06:57.896934360Z 2022-06-07T13:06:57.895Z ERROR contact:service ping satellite failed {“Process”: “storagenode”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 1, “error”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout”, “errorVerbose”: “ping satellite: rpc: tcp connector failed: rpc: dial tcp: i/o timeout\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:189”}
2022-06-07T13:06:57.896955216Z 2022-06-07T13:06:57.896Z ERROR contact:service ping satellite failed {“Process”: “storagenode”, “Satellite ID”:
