Hey guys need help
hey
who can me help? I instail the storj app for qnap and it doesn’t work.
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
what can I do to fix it
This is a third party app I believe and it hasn’t been updated in a while. Its probably best to not use it or contact the developer on github to see if you can get support for it.
If your trying to install a storagenode on qnap just do it though CLI and install it.
hey thx for help
do you know an alternative
Yeah install docker on qnap, login into ssh run the normal docker start commands. I run storj on my Nas though the binary files manually thats also an option. But everything is though SSH though.
I believe on Qnap you need to install container station (which installs docker automatically).
thx for help, it works but still wait for identity,3 days and now it fail and i must start it again
