2023-11-01T15:02:09Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2023-11-01T15:02:10Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.90.2"}
2023-11-01T15:02:10Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2023-11-01T15:02:10Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.90.2"}
2023-11-01T15:02:10Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2023-11-01T15:03:13Z ERROR services unexpected shutdown of a runner {"process": "storagenode", "name": "piecestore:monitor", "error": "piecestore monitor: timed out after 1m0s while verifying writability of storage directory", "errorVerbose": "piecestore monitor: timed out after 1m0s while verifying writability of storage directory\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func2.1:176\n\tstorj.io/common/sync2.(*Cycle).Run:160\n\tstorj.io/storj/storagenode/monitor.(*Service).Run.func2:165\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75"}
2023-11-01T15:03:28Z WARN servers service takes long to shutdown {"process": "storagenode", "name": "server"}
2023-11-01T15:03:28Z WARN services service takes long to shutdown {"process": "storagenode", "name": "retain"}
2023-11-01T15:03:28Z INFO services slow shutdown {"process": "storagenode", "stack": "goroutine 1027 [running]:\nstorj.io/storj/private/lifecycle.(*Group).logStackTrace.func1()\n\t/go/src/storj.io/storj/private/lifecycle/[...]
(big long description of stack trace removed)
Error: piecestore monitor: timed out after 1m0s while verifying writability of storage directory
2023-11-01 15:03:48,444 INFO exited: storagenode (exit status 1; not expected)
2023-11-01 15:03:49,877 INFO spawned: 'storagenode' with pid 5598
2023-11-01 15:03:49,878 WARN received SIGQUIT indicating exit request
2023-11-01 15:03:50,029 INFO waiting for storagenode, processes-exit-eventlistener, storagenode-updater to die
2023-11-01T15:03:50Z INFO Got a signal from the OS: "terminated" {"Process": "storagenode-updater"}
2023-11-01 15:03:50,030 INFO stopped: storagenode-updater (exit status 0)
2023-11-01T15:03:50Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-11-01T15:03:50Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-11-01T15:03:50Z INFO Operator email {"process": "storagenode", /* removed */}
2023-11-01T15:03:50Z INFO Operator wallet {"process": "storagenode", /* removed */}
2023-11-01T15:03:50Z INFO server kernel support for server-side tcp fast open remains disabled. {"process": "storagenode"}
2023-11-01T15:03:50Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {"process": "storagenode"}
2023-11-01T15:03:50Z INFO Telemetry enabled {"process": "storagenode", /* removed */}
2023-11-01T15:03:50Z INFO Event collection enabled {"process": "storagenode", /* removed */}
2023-11-01T15:03:51Z INFO db.migration Database Version {"process": "storagenode", "version": 54}
2023-11-01 15:03:53,068 INFO waiting for storagenode, processes-exit-eventlistener to die
2023-11-01T15:03:54Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"process": "storagenode"}
2023-11-01T15:03:55Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"process": "storagenode"}
2023-11-01T15:03:55Z INFO Node xxx started {"process": "storagenode"}
2023-11-01T15:03:55Z INFO Public server started on [::]:28967 {"process": "storagenode"}
2023-11-01T15:03:55Z INFO Private server started on 127.0.0.1:7778 {"process": "storagenode"}
2023-11-01T15:03:55Z INFO pieces:trash emptying trash started {"process": "storagenode", /* removed */}
2023-11-01T15:03:55Z INFO bandwidth Performing bandwidth usage rollups {"process": "storagenode"}
2023-11-01T15:03:55Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", /* removed */}
2023-11-01T15:03:55Z INFO trust Scheduling next refresh {"process": "storagenode", "after": "8h1m55.523334006s"}
2023-11-01T15:03:55Z INFO lazyfilewalker.used-space-filewalker subprocess started {"process": "storagenode", /* removed */}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "LGVFZBREIDM75GI62CV2Z3JZDVH4JPIKLVEZP2I4QRQA3JUZPLLA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "3XBDSNYCFQ2OCLZVBOYZ4RXANVHFRVUYRCATLQZSF2PY5JHDVYYA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "5J5IRTBXP7CAUDZPKMRJKA3Z3AMOZC2XQOUPP5TSHL52GQK5LKRA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "CEEMO7ZLMFRLY4QMADBDHY5E7BEJB5727P6DYIEVR5GDI4TUDFUA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "QZDNFHBNEMGXS5YLFQHRISU5PSMZDG2MZGGUMNEZK4JDQC35777A"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "LIWL6YJIO6UOUZTI7BFSU7OEYVBKLZRXU4XYNQ4CPYOO43RVFVHA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "PULS5CSPD2QF3TMK72MV6ZC5YU3HNY4CM5DCVDKZPNGIFOCUULQA"}
2023-11-01T15:03:55Z INFO collector deleted expired piece {"process": "storagenode", /* removed */, "Piece ID": "V4J3JE7JO476TAVPKENSL5OPXHGDSTLYFFQJWA54VDRYGT7OWDUQ"}
2023-11-01T15:03:55Z INFO collector collect {"process": "storagenode", "count": 8}
2023-11-01T15:03:55Z INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"process": "storagenode", /* removed */, "process": "storagenode"}
2023-11-01T15:03:55Z INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"process": "storagenode", /* removed */, "process": "storagenode"}
2023-11-01 15:03:57,061 INFO waiting for storagenode, processes-exit-eventlistener to die
2023-11-01 15:04:00,064 WARN killing 'storagenode' (5598) with SIGKILL
2023-11-01 15:04:00,064 INFO waiting for storagenode, processes-exit-eventlistener to die
2023-11-01 15:04:00,690 INFO stopped: storagenode (terminated by SIGKILL)
2023-11-01 15:04:00,691 INFO stopped: processes-exit-eventlistener (terminated by SIGTERM)
2023-11-01 15:06:14,516 INFO Set uid to user 0 succeeded
2023-11-01 15:06:14,612 INFO RPC interface 'supervisor' initialized
2023-11-01 15:06:14,613 INFO supervisord started with pid 1
2023-11-01 15:06:15,617 INFO spawned: 'processes-exit-eventlistener' with pid 10
2023-11-01 15:06:15,623 INFO spawned: 'storagenode' with pid 11
2023-11-01 15:06:15,628 INFO spawned: 'storagenode-updater' with pid 12
2023-11-01T15:06:15Z INFO Configuration loaded {"Process": "storagenode-updater", "Location": "/app/config/config.yaml"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "console.address"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-disk-space"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.private-address"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "healthcheck.details"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.email"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "contact.external-address"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "storage.allocated-bandwidth"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet-features"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "server.address"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "operator.wallet"}
2023-11-01T15:06:15Z INFO Invalid configuration file key {"Process": "storagenode-updater", "Key": "healthcheck.enabled"}
2023-11-01T15:06:15Z INFO Anonymized tracing enabled {"Process": "storagenode-updater"}
2023-11-01T15:06:15Z INFO Configuration loaded {"process": "storagenode", "Location": "/app/config/config.yaml"}
2023-11-01T15:06:15Z INFO Anonymized tracing enabled {"process": "storagenode"}
2023-11-01T15:06:15Z INFO Operator email {"process": "storagenode", /* removed */}
2023-11-01T15:06:15Z INFO Operator wallet {"process": "storagenode", /* removed */}
2023-11-01T15:06:15Z INFO Running on version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.90.2"}
2023-11-01T15:06:15Z INFO Downloading versions. {"Process": "storagenode-updater", "Server Address": "https://version.storj.io"}
2023-11-01T15:06:15Z INFO server kernel support for server-side tcp fast open remains disabled. {"process": "storagenode"}
2023-11-01T15:06:15Z INFO server enable with: sysctl -w net.ipv4.tcp_fastopen=3 {"process": "storagenode"}
2023-11-01T15:06:16Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode", "Version": "v1.90.2"}
2023-11-01T15:06:16Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode"}
2023-11-01T15:06:16Z INFO Current binary version {"Process": "storagenode-updater", "Service": "storagenode-updater", "Version": "v1.90.2"}
2023-11-01T15:06:16Z INFO Version is up to date {"Process": "storagenode-updater", "Service": "storagenode-updater"}
2023-11-01T15:06:16Z INFO Telemetry enabled {"process": "storagenode", /* removed */}
2023-11-01T15:06:16Z INFO Event collection enabled {"process": "storagenode", /* removed */}
2023-11-01 15:06:17,287 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-11-01 15:06:17,287 INFO success: storagenode entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-11-01 15:06:17,287 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
2023-11-01T15:06:17Z INFO db.migration Database Version {"process": "storagenode", "version": 54}
2023-11-01T15:06:18Z INFO preflight:localtime start checking local system clock with trusted satellites' system clock. {"process": "storagenode"}
2023-11-01T15:06:19Z INFO preflight:localtime local system clock is in sync with trusted satellites' system clock. {"process": "storagenode"}
2023-11-01T15:06:19Z INFO bandwidth Performing bandwidth usage rollups {"process": "storagenode"}
2023-11-01T15:06:19Z INFO Node xxx started {"process": "storagenode"}
2023-11-01T15:06:19Z INFO Public server started on [::]:28967 {"process": "storagenode"}
2023-11-01T15:06:19Z INFO Private server started on 127.0.0.1:7778 {"process": "storagenode"}
2023-11-01T15:06:19Z INFO pieces:trash emptying trash started {"process": "storagenode", /* removed */}
2023-11-01T15:06:19Z INFO trust Scheduling next refresh {"process": "storagenode", "after": "3h59m29.796946439s"}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker starting subprocess {"process": "storagenode", /* removed */}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker subprocess started {"process": "storagenode", /* removed */}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker.subprocess Database started {"process": "storagenode", /* removed */, "process": "storagenode"}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker started {"process": "storagenode", /* removed */, "process": "storagenode"}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker.subprocess used-space-filewalker completed {"process": "storagenode", /* removed */, "process": "storagenode", "piecesTotal": 47153346816, "piecesContentSize": 47141446912}
2023-11-01T15:06:19Z INFO lazyfilewalker.used-space-filewalker subprocess finished successfully {"process": "storagenode", /* removed */}
2023-11-01T15:06:20Z INFO pieces:trash emptying trash started {"process": "storagenode", /* removed */}
