I’ve find the QNAP TS-332 with a 10Gbe port : https://www.qnap.com/en/product/ts-332x
Cost affordable and looks okay for high speed connexion.
Keep in mind that not only your NAS needs 10GBe, but your switch + router as well.
Also, is your internet speed 200/200 Mbit/s?
-> because that would translate to max. 25 MB/s, which is no problem for a 1GBe device!
Hey @twl
Bellow you will find my speed test. I live in France and we have a very decent network connexion with fiber. I can push it to 600/600 if needed with few adjustment with my operator.
If I have this result on my computer does it mean my switch + router is well configurated ?
So if I well understand your point, 1GBe is okay for my connexion ?
Yes, this looks perfect for a 200/200 connection! 7ms ping is also very good for europe.
And as I said, since you have 200MBit/s internet, you are fine with a 1GBe (=1000mbit/s) NAS ![]()
/EDIT:
Yep, exactly
@twl Thank you a lot for these infos, you’ve help me to save money and time in research. So I will be able to go on a DS218+ with only one HDD at the moment to see if everything goes well when I host a node.
I keep you in touch as soon as possible
