How about GlusterFS? I am planning to build a DIY NAS and use GlusterFS as my filesystem. I’m planning to run my node on the NAS and point my Storj’s docker container to the mounted GlusterFS folder using GlusterFS client.
Many thanks in advance.
i think glusterfs might have an inode issue limitation, when you get into the millions and millions glusterfs becomes a bit slow… i’m not fully aware of how much of a real problem this is of if it just means that it takes a while to open a folder with millions of files in it…
anyways, there is something about glusterfs and millions of files creating latency or issues, might be worth looking into first.
Hello @aharandi,
And
And Search results for 'glusterfs' - Storj Community Forum (official)
