How fast can the hard drive fill?
Hello Guys,
I’m about to make my first steps as a node operator.
I was wondering as i saw in this forum a storj earning estimation, is there a cap to fill the hdd ?
Like this ? 4.84 To per month ?
Because i actually have 5 x 4 To. So should i make it to 5 nodes of 4 To, or 1 node of 5 x 4 To ?
Thanks for reading me :slight_smile:
You should make separate nodes, because combining them would either mean one HDD failure and you lose everything or you need to set up RAID and would lose usable space. However, as you already saw in the estimator, it’s going to take a long time to fill 20TB. I suggest starting with one node and wait until it’s vetted. After that you can start 1 or 2 more. You can always add more once the first few start filling up. But there is not need to spend the power on keeping the other HDD’s spinning until they start filling up a bit.
That’s not what it says, that says after a year you would have about 4.84TB stored total. Not per month. At current traffic, it’ll take 5 years to fill up 15TB and you may never reach 20TB. One node or more node doesn’t matter as incoming traffic is shared on the same IP subnet. So you don’t get more incoming data if you run more nodes.
What happens if you have 2 nodes on different networks? As in different IPs? Will they fill up storage quicker?
per /24 ip subnet, not per ip.
I run a single node and in 7 months have 1.51TB and just vetted on all satellites. I will get to 2TB at about 9 months (large deletes going on at moment)
