How long does it take to update Bandwidth on tardigrade.io/project-dashboard?
Yesterday I uploaded two files to Tardigrade via Uplink. The project dashboard says that 382.06MB of 5 GB has been used, while the bandwidth usage has not been updated.
How long does it take to update Bandwidth on tardigrade.io/project-dashboard? Does it take around a day? Thanks,
Clipboard01
Please, go to the Billing and click on Usage charges, then - Advanced report.
Do you see a bandwidth usage for the bucket in question?
It seems reasonable that it would stay at 5.00 remaining since they don’t charge for upload bandwidth. I’d expect to see that number change if the data is downloaded from Tardigrade.
Would you mind indicating which document claims so? I would like to confirm that before I set up a cron job to upload a database backup weekly. Thanks in advance,
Thank you very much.
