How long has my node been up according to Storj?
Hi,
Not sure if this is a dumb question or not but here goes…
I have two nodes happily chugging away and I was trying to work out how all this escrow stuff works, which then caused me to wonder how long my nodes have been running for each identity?
How do I determine that from the perspective of Storj, not my dodgy memory :slight_smile: ?
Cheers
A
You could run earnings calculator and it will show you first contact for each satellite.
There is no such thing.
Nice - thanks @nerdatwork ! :slightly_smiling_face:
If you have saved passwords and storj information in Keepass, it tells you when you created the password :smile:
