Hello,
I have setup my node to receive the payout over Polygon, how I can add STORJ token on Metamask wallet ?
If I try to Import STORJ on polygon network on my Metamask wallet I can find any:
Thanks
Fabrizio
Hello,
Thanks
Fabrizio
you need to do something like this… haven’t tried this guide myself, but look look through it and it seems fine.
ofc its always a good idea to verify guides from multiple sources, basically it says you need to add the polygon network first.
i think…
I already have connected Polygon network to my Metamask, as u can see from the pics that I have attached on previous post but I cant import STORJ token on Polygon Network
You can goto Polygon Web Wallet v2 then when your see storj you can add it to metamask.
You need to change one of the settings to all polygon tokens.
